C129 error in keil C
sahilt
Jul 23, 2012
8
hey guys..i am currently working on a program on keil and i am not able to compile it coz everytime i try, i gives me an error C129: missing ';' before '\'. Can anyone plz help me? The program is as follows:
rtf1\ansi\ansicpg1252\deff0\deflang1033{\fonttbl{\f0\fnil\fcharset0 Calibri;}
{ \*\generator Msftedit 5.41.21.2509;}\viewkind4\uc1\pard\sa200\sl276\slmult1\lang9\f0\fs22 #include <reg51.h> \par
//#include <header.h> \par
//#include "lcd.h" \par
#define adc_port P1\par
#define lcd_port P2\par
sbit rd=P3^7; //Read signal P3.7 \par
sbit wr= P3^6; //Write signal P3.6 \par
sbit cs= P3^5; //Chip Select P3.5 \par
sbit intr= P3^4; //INTR signal P3.4 \par
sbit rs= P3^0;\tab\tab //lcd_port P2 \par
sbit rw= P3^1;\par
sbit en= P3^2;\par
sbit flag= P2^7;\par
void conv(); //Start of conversion function\par
void read();\par
void delay(unsigned int);\par
unsigned int adc_avg, adc; \par
void wrt_cmd(unsigned char);\par
void wrt_data(unsigned char);\par
void wrt_string(unsigned char *);\par
void LCD_INI(void);\par
void busy(void);\par
void hex2lcd(unsigned char);\par
\par
\par
void main()\par
\{\par
unsigned char i,encoder;\par
P1=0xff;\par
P3=0x8f;\par
P0=0x00; //output port\par
\par
LCD_INI();\par
wrt_string("Voltage Display");\par
while (1) //Forever loop\par
\{ \tab\par
\tab adc_avg = 0;\par
\tab for (i = 0; i < 10; i++) \par
\tab\{\par
\tab\tab conv(); //Start conversion\par
\tab\tab read(); //Read ADC\par
\tab\tab adc_avg += adc;\par
\tab\}\par
adc_avg = adc_avg / 10;\par
encoder=adc_avg&0xf0; //get high order 4 bit in encoder\par
encoder=encoder>>4;\par
P0=encoder;\par
wrt_cmd(0xC0);\par
wrt_string("V(DC): ");\par
adc = adc_avg * 59;\par
hex2lcd((unsigned char) (adc / 1000));\par
wrt_data('.');\par
adc = adc % 1000;\par
hex2lcd((unsigned char) (adc / 10));\par
wrt_data('V');\par
\}\par
\}\par
\par
void conv()\par
\{\par
cs = 0; //Make CS low\par
wr = 0; //Make WR low\par
wr = 1; //Make WR high\par
cs = 1; //Make CS high\par
while (intr); //Wait for INTR to go low\par
\}\par
void read()\par
\{\par
rd = 0; //Make RD low\par
adc = adc_port; //Read ADC port\par
rd = 1; //Make RD high\par
\}\par
/*\par
void busy()\par
\{\par
flag = 1;\par
rs = 0;\par
rw = 1;\par
while (flag != 0) \{\par
en = 0;\par
en = 1;\par
\}\par
\} */\par
\par
void wrt_cmd(unsigned char val_lcd)\par
\{\par
//busy();\par
lcd_port = val_lcd;\par
rs = 0;\par
rw = 0;\par
en = 1;\par
en = 0;\par
delay(500);\par
\}\par
\par
void wrt_data(unsigned char dat)\par
\{\par
//busy();\par
lcd_port = dat;\par
rs = 1;\par
rw = 0;\par
en = 1;\par
en = 0;\par
delay(500);\par
\}\par
\par
void wrt_string(unsigned char *string)\par
\{\par
while (*string)\par
\tab wrt_data(*string++);\par
\}\par
\par
void LCD_INI(void)\par
\{\par
wrt_cmd(0X38);\par
wrt_cmd(0X38);\par
wrt_cmd(0X38);\par
wrt_cmd(0X38);\par
wrt_cmd(0X06);\par
wrt_cmd(0X0e);\par
wrt_cmd(0X01);\par
wrt_cmd(0X80);\par
\}\par
\par
void delay(unsigned int i)\par
\{\par
while(i--);\par
\}\par
\par
void hex2lcd(unsigned char hex)\par
\{\par
char temp1, temp2;\par
temp1 = hex;\par
temp2 = 0;\par
do \{\par
temp1 = temp1 - 100;\par
if (temp1 >= 0)\par
temp2++; \par
\} while (temp1 >= 0);\par
if (temp2 > 0)\par
wrt_data(temp2 + 0x30);\par
temp2 = 0;\par
temp1 = temp1 + 100;\par
do \{\par
temp1 = temp1 - 10;\par
if (temp1 >= 0)\par
temp2++;\par
temp2 = temp1 + 10;\par
\} \par
Try:
a) posting it again without the formatting
b) telling us on which line it reports the error.
sahilt
Jul 23, 2012
8
okk...thanks steve..,i'll do that...but its just reporting the error C129 on the very first line that is:
rtf1\ansi\ansicpg1252\deff0\deflang1033{\fonttbl{\ f0\fnil\fcharset0 Calibri;}
and i have no idea why this is happening... as i mentioned in my first post: C128 missing ';' before '\'
Some help would be appreciated. Thanks in advance!!
I'm pretty sure your first line doesn't look like that.
Perhaps you should try a plain ascii file, not what appears to be rtf.
Using a PC? Copy and paste it into notepad.
sahilt
Jul 23, 2012
8
oh!! ok...sorry if i did something wrong...i am simply copying and pasting my program in keil into the notepad. And when i try to look for the error ..all it points to is the very first line....dats wat i don't understand..
//#include <reg51.h>
//#include "lcd.h"
#define adc_port P1
#define lcd_port P2
sbit rd=P3^7;
sbit wr= P3^6;
sbit cs= P3^5;
sbit intr= P3^4;
sbit rs= P3^0;
sbit rw= P3^1;
sbit en= P3^2;
sbit flag= P2^7;
void conv();
void read();
void LCD_INI(void);
void busy(void);
void main()
P1=0xff;
P3=0x8f;
P0=0x00;
LCD_INI();
while (1)
tab adc_avg = 0;
for(i = 0; i < 10; i++)
conv();
read();
adc_avg += adc;
encoder=encoder>>4;
P0=encoder;
wrt_cmd(0xC0);
adc = adc_avg * 59;
wrt_data('.');
adc = adc % 1000;
wrt_data('V');
void conv()
cs = 0;
wr = 0;
wr = 1;
cs = 1;
while (intr);
void read()
cs = 0;
rd = 0;
adc = adc_port;
rd = 1;
cs = 1;
void busy()
flag = 1;
rs = 0;
rw = 1;
while (flag != 0)
en = 0;
en = 1;
busy();
lcd_port = val_lcd;
rs = 0;
rw = 0;
en = 1;
en = 0;
delay(500);
busy();
lcd_port = dat;
rs = 1;
rw = 0;
en = 1;
en = 0;
delay(500);
while (*string)
void LCD_INI(void)
wrt_cmd(0X38);
wrt_cmd(0X38);
wrt_cmd(0X38);
wrt_cmd(0X38);
wrt_cmd(0X06);
wrt_cmd(0X0e);
wrt_cmd(0X01);
wrt_cmd(0X80);
while(i--);
char temp1, temp2;
temp1 = hex;
temp2 = 0;
do {
if (temp1 >= 0)
temp2++;
if (temp2 > 0)
temp2 = 0;
do {
temp1 = temp1 - 10;
if (temp1 >= 0)
temp2++;
temp2 = temp1 + 10;
Delete these 2 lines and try again:
{ \*\generator Msftedit 5.41.21.2509;}\viewkind4\uc1\pard\sa200\sl276\slmu lt1\lang9\f0\fs22
sahilt
Jul 23, 2012
8
umm..i don't think so steve..but still as you suggested,i tried doing so and after compiling the program..it gave many more errors like:
Build target 'Target 1'
compiling trans1.c...
TRANS1.C(6): error C202: 'P3': undefined identifier
TRANS1.C(7): error C202: 'P3': undefined identifier
TRANS1.C(8): error C202: 'P3': undefined identifier
TRANS1.C(9): error C202: 'P3': undefined identifier
TRANS1.C(10): error C202: 'P3': undefined identifier
TRANS1.C(11): error C202: 'P3': undefined identifier
TRANS1.C(12): error C202: 'P3': undefined identifier
TRANS1.C(13): error C202: 'P2': undefined identifier
TRANS1.C(27): error C202: 'P1': undefined identifier
TRANS1.C(28): error C202: 'P3': undefined identifier
TRANS1.C(29): error C202: 'P0': undefined identifier
TRANS1.C(34): error C202: 'tab': undefined identifier
TRANS1.C(34): error C141: syntax error near 'adc_avg'
TRANS1.C(44): error C202: 'P0': undefined identifier
TRANS1.C(57): error C202: 'cs': undefined identifier
TRANS1.C(58): error C202: 'wr': undefined identifier
TRANS1.C(59): error C202: 'wr': undefined identifier
TRANS1.C(60): error C202: 'cs': undefined identifier
TRANS1.C(61): error C202: 'intr': undefined identifier
TRANS1.C(65): error C202: 'cs': undefined identifier
TRANS1.C(66): error C202: 'rd': undefined identifier
TRANS1.C(67): error C202: 'P1': undefined identifier
TRANS1.C(68): error C202: 'rd': undefined identifier
TRANS1.C(69): error C202: 'cs': undefined identifier
TRANS1.C(73): error C202: 'flag': undefined identifier
TRANS1.C(74): error C202: 'rs': undefined identifier
TRANS1.C(75): error C202: 'rw': undefined identifier
TRANS1.C(76): error C202: 'flag': undefined identifier
TRANS1.C(78): error C202: 'en': undefined identifier
TRANS1.C(79): error C202: 'en': undefined identifier
TRANS1.C(85): error C202: 'P2': undefined identifier
TRANS1.C(86): error C202: 'rs': undefined identifier
TRANS1.C(87): error C202: 'rw': undefined identifier
TRANS1.C(88): error C202: 'en': undefined identifier
TRANS1.C(89): error C202: 'en': undefined identifier
TRANS1.C(95): error C202: 'P2': undefined identifier
TRANS1.C(96): error C202: 'rs': undefined identifier
TRANS1.C(97): error C202: 'rw': undefined identifier
TRANS1.C(98): error C202: 'en': undefined identifier
TRANS1.C(99): error C202: 'en': undefined identifier
TRANS1.C(146): error C141: syntax error near '}'
Target not created
so when i again included the lines, it gave back the same error..
TRANS1.C(1): error C129: missing ';' before '\'
Well, maybe there is something in those first 2 lines that are your actual code. I can't tell.
Presumably you know what the code should look like, and presumably that alphabet soup isn't all part of it.
But it is certainly true that P1, P2, etc do not appear to be defined.
And what is interesting is that you assign values to them in code even though your gobal variables seem to have initial values based on their (undefined) values.
I think these errors are real.
sahilt
Jul 23, 2012
8
so...wat exactly do you mean by these errors are real..??
And is there anyway you could suggest on how I could solve my problem??
The errors appear real because now the code appears wrong.
Define P1 and P2 (etc) and some of your errors will go away.
Then work on the rest.
Perhaps one of those commented out includes contains the definitions. Why do you have them commented out?
