CommanderLake
- Oct 2, 2012
- 227
- Joined
- Oct 2, 2012
- Messages
- 227
I've been designing a 7.1 amplifier board (7 amps and sub out) with built in volume control and I want to add some protection with a DPDT relay that switches the + and - of the smoothing caps to a large resistor to discharge them, the supply will be effectively 61v from + to - so if I use a 47v zener in series with a 12v relay it will only turn on when both capacitors are charged, this should protect against power on transients if the charge of the capacitors is uneven and any DC at the outputs after power off and if one of the fuses blow on either supply rail the caps will be cut off.
I will need a relay thats not center off but looking at THESE on Farnell Its not clear if they are center off or not, take THIS for example I cant find anything in the datasheet (link on product page) that says if its center off?
So what do you think of the zener idea?
