- Joined
- Nov 28, 2011
- Messages
- 8,393
Try again; I've just updated that post with a complete diagram.
This has worked in the simulation.
What do you think ?
The voltage divider (R1 and R2) and C1 improve the circuit's immunity to noise on the RS-232 data line. C1's value is chosen to suit data rates up to 9600 bps. If the GPS receivers use a data rate higher than that, C1 must be reduced accordingly. D1 protects Q1 from possibly damaging negative base voltage.
Yes, 4800 bps is fine.
You're welcome; no problem.
Good luck!
