Making an FM Transmitter
vick5821
Jan 22, 2012
700
Hey there ! Recently I am working on a simple mini project which ia making a FM transmitter.
I get my reference from this website : http://www.minibread.com/modules/blockblog/blockblog-post.php?post_id=5
However, according to the schematic, I am not able to get S9018 transistor and 5.5T inductor. What other transistor can replaced that ? Can I use a 6.8micro inductor instead ?
Thanks for the opinion and help !
Greetings,
Vincent
OLIVE2222
Oct 2, 2011
690
Hi Vincent,
You can use a BC547 or a 2N2222 or similar for the transistor.
For the inductor 6.8µH will be to high, the BOM state 0.1µH, you can easily made the inductor yourself with a piece of rigid electrical wire of around 1mm of diameter
Olivier
vick5821
Jan 22, 2012
700
Hi Vincent,
Olivier
What is the reasonable range for the inductor ? possible for me to parallel a few 6.8uH inductor ?
Thanks !
vick5821
Jan 22, 2012
700
CDRIVE
May 8, 2012
4,960
Ahh, I cant find such hard core wire for now. I only have normal single core wire which is quite weak.
You're not going to be supporting a high rise with it. :rolleyes: Trench soldiers worked with much less. ;)
Chris
vick5821
Jan 22, 2012
700
Hi Vincent,
Olivier
Is it possible for me to use 2N3904 NPN transistor ? Thanks !
CDRIVE
May 8, 2012
4,960
Is that possible for me to measure the output frequency of my circuit ?
Thanks !
The odds are that you don't posses a frequency counter, grid or gate dip meter or a scope capable of measuring this. This leaves you with what you have, which is the FM receiver itself.
Chris
vick5821
Jan 22, 2012
700
I made a FM transmitter and the receiver able to receive it. But not stable. Any ways to make it stable and longer range ?
Thanks!
OLIVE2222
Oct 2, 2011
690
Well this is a very basic circuit, for best stability use a NPO type capacitor for C4 and build the circuit above a ground plane are probably the only possible improvement. For better stability you need a crystal or a PLL.
For longer range you can locate the transmitter in a higher position and/or use a good antenna.
Olivier
vick5821
Jan 22, 2012
700
Olivier
I am building this circuit,
Thanks! :D
