FAN5345
OLIVE2222
Oct 2, 2011
690
Yes a simple switch will be able to drive the pin 4, but as suggested by Steve, better to let the pin unconnected in order first start at full brightness.
lechik86
Jun 2, 2014
17
Okay I've left pin 4 open. It still didn't light up. :|
lechik86
Jun 2, 2014
17
Okay I've tried reconnecting pin 4 to the switch and leave just one LED on board. It lit up. But pressing the switch doesn't dim it.
OLIVE2222
Oct 2, 2011
690
OK, but we have a simpler setup to work with. Can you post a sharp picture of the small PCB ?
Are you aware of the pin numbering not like on any of the datasheet schematics but like on the pin configuration paragraph (just in case) ?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
As Steve said, I would be concerned about that inductor. It looks pretty small, and 1 ohm resistance is pretty high for such a small inductance. I think it's just a signal inductor for noise suppression in medium- to high-impedance applications. Try using one that's rated for at least 1A such as http://www.digikey.com/product-detail/en/RLB0712-100KL/RLB0712-100KL-ND/2561284
I would also use a piece of stripboard or some other solder-based prototyping board, and minimise lead lengths, for all of the switching circuitry at least, instead of breadboard.
lechik86
Jun 2, 2014
17
I'd like to ask something about these values:
EN Low Time for Dimming = 0.5us (min), 300us (max)
Delay Between Steps = 0.5us (min), 300us (max)
EN Low, Shutdown Pulse Width = 1ms (max)
Maximum Boost Duty Cycle = 85%
Minimum Boost Duty Cycle = 20%
Can this be achieved by connecting a switch directly to EN? Thanks.
lechik86
Jun 2, 2014
17
By the way, here's the electrical specification sheet of FAN5345.
