Ok this is the scenario :
I setup my circuit on a breadboard. After weeks of tinkering I reach to the point of satisfaction, then I grab my PCB board design software, draw the schematic and send the final PCB document to a factory.
After getting my PCB board, I solder the components, and switch the power on. Alas ! It ALWAYS DOES NOT work !
I usually take the components off from that already built breadboard design. Now I have a PCB board that somehow does not work and I also do not have that already working breadboard !
On PCB board I can't measure currents but only voltages, so I check here and there and look for short circuits and etc.. then I desperately replace some suspected components; After lots of failed attempt I give up and again have to set up the circuit in breadboard... and this cycle goes for a lot of times until I get a working PCB.
How about you ? How do you do this procedure properly ?
