24v solar panel, have 12v invertor. Wondering if this will work.
Loe 4520
Mar 2, 2018
7
I have 2, expensive, 24v solar panels, never used, that I don't know what to do with. So, I was wondering if I could make a 12v system work by putting 2, 12v batteries in series and using the panels to charge them, and just pull the load to the inverter I already have off the LH battery as per the diagram. Would the RH battery keep the LH battery backfed ? In this diagram, the solar panels would obviously be connected to the top with a charge controller. Also, load 2 would not be used.
Thanks for any ideas.
duke37
Jan 9, 2011
5,364
The batteries will become unbalanced if the loads are not identical. One will be overcharged and one undercharged.
Better to use a 24V to 12V buck convertor to charge both 12V batteries in parallel or a 24V to 12V buck convertor supplied from the batteries in series to both outputs.
