Getting Decimal value instead of hex
BHARGAV SHANKHALPARA
Nov 6, 2013
35
Hi all...
i am programming ATMEGA32 microcontroller and ATMEL STUDIO 6 for programming in my application.
in my application user enter 3 difference value which i have store in char variable.
At the end i combine this 3 value in one variable and compare it with predefine value. when i combine in one variable it automatically convert into decimal.
for example i have 3 variable named S1,S2,S3
user enter S1=2,S2=0,S3=9;
at end combine value in TOTAL variable which is INT.
TOTAL = (S3 | (S2 << 4) | (S1 << 8));
so TOTAL value should be 209
but it shows after decimal conversation 521.
when i compare it with 209 this gives no result, but it gives result when my predefine value 521.
i want to get result when user enter 209 and my predefine value also 209.
Harald Kapp
14,308
S1=2, S1 << 8 = S1*256 = 2*256 = 512
S2=0, S2 << 4 = S2* 16 = 0*16 = 0
S3=9
-> (S3 | (S2 << 4) | (S1 << 8)) = 521, not 209.
decimal 521 = 0x209 (hex).
The issue is with the shift statements. You want the decimal number 209 to be entered as single digits in the sequence 2*100+0*10+9*1. Therefore you cannot use shift operations, which will multiply by powers of 2.
You need to construct the INT representation from the input as follows:
TOTAL = 100*S1+10*S2+S3;
If your math library is too slow, you can speed up the operations for *10 and *100 by substituting it by
Code:
10_times(int x)
return x<<3 + x<1; /* x<<3 = x*8, x<<1 = x*2 */
100_times(int x)
return 10_times(x)*10_times(x)
You can also use macros (#define ...) to avoid the subroutine call and generate inline code instead.
Nov 6, 2013
35
S3=9
Code:
10_times(int x)
100_times(int x)
hi
Harald Kapp...
Thank you so much...as you told i have done. its working correctly.
Thanks again
Harald Kapp
14,308
I'm sorry, I detected a flaw in my code:
Code:
10_times(int x)
100_times(int x)
/* wrong code :
return 10_times(x)*10_times(x); -> this will give 100*x^2
/* correct code */
return 10_times(10_times(x)); /* this will give 10*10*x = 100*x
Nov 6, 2013
35
Code:
10_times(int x)
100_times(int x)
/* wrong code :
/* correct code */
But i have done this way...
and its working good...!!
Thanks...
kpatz
Feb 24, 2014
334
If your math library is too slow, you can speed up the operations for *10 and *100 by substituting it by...
Fixed a typo in 10_times below:
Code:
10_times(int x)
return x<<3 + x<<1; /* x<<3 = x*8, x<<1 = x*2 */
100_times(int x)
Harald Kapp
14,308
yep, thanks
Just for Bhargav's information: The typo is highlighted here in bold font:
return x<<3 + x<<1;
