- Joined
- Nov 28, 2011
- Messages
- 8,393
I wasn't meaning to imply that I think you're lazy. Far from it!
I guess drill distance means drill travel, which is the total distance that each size of drill bit needs to travel, in order to drill all the holes of that size on the board. Minimising drill travel will make the drilling process slightly quicker, but it's not
One other thing though.
I would reroute the VCC track to pin 8 of the right hand Allegro chip, starting from pin 1 of the PIC on the underside (instead of the pin on CN4). Run it between pins 5 and 6 of the PIC, under the resistor, up past the transistor, then across to the Allegro chip.
For the track from pin 7 of the Allegro chip, I would take that straight down through a via to the underside, to the left, between the base and emitter of Q2, and up to pin 5 of the PIC.
You might want to move Q2 rightwards a bit first.
Just some suggestions.
