SPECS
HIGH-POWER GaAlAs IRLED ILLUMINATOR
Spec Sheet
http://optodiode.com/pdf/OD669-850.pdf
V72 Laptop Battery
Output: 5V/2A USB, and 12V/4A, 16V/3.5A, 19V/3A
http://www.voltaicsystems.com/v72
If I wanted to power this LED From this Battery what kind of resistance would I need?
That’s the question, here’s the filler.
I know this should be a super basic question, I’ve really only started seriously trying to understand electricity two days ago, but yesterday I really struggled with this, and this morning I still haven’t wrapped my brain around it. I’ve chosen “Make: Electronics” as my starting point in this world of electricity.
If my battery is capable of outputting 16V/3.5A then I need to resist the current to a level that doesn’t exceed my LED to avoid frying it. My voltage should not need to be affected because 16v is within the limits of the LED.
But here’s where I’m confused:
from what I understand when Voltage travels in a circuit it is affected by resistors, by increasing or decreasing the resistance you adjust voltage pressure or the “potential difference”
But if you add the voltage drops across the devices in the circuit, the total is the same as the voltage supplied by the batteries.
In this case I don’t think I need to limit my voltage if I use the batteries 16V/3.5A output setting.
Now comes the Amperage, the continuous forward current of this LED is 370mA, that’s a lot lower then what the battery is capable of putting out. So I need to add some resistance to reduce the current.
in this circuit I want to produce the most IR light from my LED as possible but I don’t want to fry it, so would 300mA be a good amount to supply the LED with?
But how do I reduce the Amperage so much without affecting the voltage?
How do I apply Ohms Law here?
Lets say I set the battery to output 19V/3A. (Because I’m not sure if I can use a resistor if my voltage is already perfect but my amperage isn’t.)
Then the difference of voltage between my led and my battery is 3V, this is the number I will use in my ohms law
I only need 300mA to flow thru the LED. So .3A is the number ill use in ohms law.
R = V/I
R = 3/.3
R = 10Ω
That just looks weird to me its such a small amount of resistance.
am I actually supposed to sumbtract the A the the LED with use with the A the batterie supplies? Like we do with the voltage?
so would I really be:
R = V/I
R = 3/2.7
R = 1.11Ω
I thing thats weird to!
But let’s say I wanted to run the 16V/3.5A setting on the battery.
Then my formula would look like:
R = V/I
R= 0/.3
R = WHHHAAAAT… you cant do that!
Do you see how I’m confused? How can I put an LED in a circuit when there is no resistance? It will fail…
What am I doing wrong, and why doesn’t my brain understand this, can you help?
I’m sorry for hopping on your fourm and asking for help so soon without really getting to know anyone, But I’m lost hopefully this confusion was decently explained and you can help re-wire my neurons.
This isn’t a School project it’s just a bit of self-directed confusion.
I also realize the theory must be the same for a regular led and a say a 6v bat. but this is more fun.
Spec Sheet
V72 Laptop Battery
R = V/I
R = 3/.3
R = 10Ω
R = V/I
R = 3/2.7
R = 1.11Ω
R = V/I
R= 0/.3
