So essentially what you did was to add a 0.047µF capacitor in parallel with a 0.47µF capacitor and expected to see a large effect. If you added a 0.47µF capacitor instead, then I would expect to see ~6dB attenuation of the disturbance.
This is an existing fixture that I would like to convert into a LED if possible. It has a power cord coming into the device with a bulb holder. I was hoping for a small solution and to just reuse the power cord. Cap fed supply's are fairly common, but I noted that you are not a fan of them. Why is that?
So do a progression: What would be the reactance of each capacitor at 120Hz? 600Hz? 6kHz? 60kHz? At what point would the 47nF capacitor overpower the the 0.47µF capacitor?
I think so. For an LED driver, where everything is inaccessible, I don't think there's much danger, and capacitor-fed power supplies are widely used. (Although that doesn't necessarily mean they're safe... Safety is always relative I guess, and it sure is possible for a manufacturer to make unsafe products when they care more about costs than safety - this also applies to circuits that should be isolated.)They are dangerous, lol.
Honestly I am a bit perplexed why Chris is posting schematics of line driven circuits that DO NOT have galvanic isolation...not typical of him or this forum...but then perhaps I am being overly cautious....
What are the cheaper, safer alternatives?I just can't see the cost/risk/reward ratio favoring this approach when there are cheaper, safer alternatives readily available.
LOLBut by all means, carry on, lol, it is truly rare that I am the one promoting safety!
What should be obvious is that the reactance of Cin will always be ten times less than the added shunt capacitor at any frequency, so that the greater part of any transient will always flow through Cin. If you need transient protection then add some inductance in series with Cin (possibly a ferrite bead or two).Obviously, the interference current will split 50/50 between them when its equivalent frequency is ten times the mains frequency, or more.
Well, I tried adding a 47 nF capacitor from point B to Neutral and it made hardly any difference to the peak current through the bridge diodes when a disturbance is applied. I don't know why, but I trust LTSpice. (Not necessarily in all cases, but in this case, I trust it.)
My disturbance was a pulse waveform of 0V/30V with 1 µs rise and fall times, added to the 115V AC RMS input voltage. I would have expected the 47 nF capacitor to absorb those fast edges, but it didn't. I wish I knew why.
Yes that's true. At high frequencies, both caps will have reactances so low that most of the interference will be dropped across the input resistor, but the rest will be split between the two capacitors, and most will still flow into the bridge.What should be obvious is that the reactance of Cin will always be ten times less than the added shunt capacitor at any frequency, so that the greater part of any transient will always flow through Cin. If you need transient protection then add some inductance in series with Cin (possibly a ferrite bead or two).
No; they take far too long to heat up. An inductor would help, but a suitable one would be big and heavy.Can we approach this differently and perhaps use a PTC?
I forgot to mention: With circuit 3, if the LED path (3RS or 3LED) goes open circuit, the smoothing capacitor, 3CS, will charge up to a high voltage and probably explode! Replacing 3D3 and 3D4 with 18V zener diodes (assuming 3CS is rated for 25V) will solve that problem.
Gave it a shotNo; they take far too long to heat up. An inductor would help, but a suitable one would be big and heavy.
I've ordered one, so in a month or so I will be able to say whether I was right, or whether "Chihui" were able to make an isolated, safe, 3.6W power supply for USD 0.99! I will post again on this thread.
I stand corrected! In the fourth picture of the link you posted, there is a 4 legged surface mount component that probably is a SMPS. I guess I overlooked the economy of scales that are being leveraged by these companies proximity to the factories of these components.I have ordered many different wattages of these: http://www.ebay.com/itm/New-LED-Pow...930?pt=LH_DefaultDomain_2&hash=item5403592dc2 from various sellers and they are in-fact SMPS CC supplies. Some of them use a tiny controller and an external switch and others use an integrated controller//switch in a slightly larger package....The price on them has been coming down steadily for the last 18 months or so....But if you think about it, if you are going to build an LED light bulb for the mass consumer market for << $10/bulb retail price range, you can't spend much more than $1.00 on the driver, and if you want it UL approved for 85V-265V you likely have to incorporate an isolated SMPS, NOT a passive/reactive line coupling...I am NOT suggesting that these supplies are in ANY WAY UL approved, but they are considerably safer than a passive current limiting circuit and cost the same or less. And, NO, I wouldn't build one for what they are selling them for, LOL.
Fish
