Mono plays the same sound through both speakers, stereo seperates the audio to a left and right channel... so some music has lyrics or other instruments shifted to one side more than the other. It give the music more depth, and a more realistic feel.what is the difference between mono and stereo?
what will be the effect?
I can do that. Sit tight and I'll get something drawn up.Gryd3 I wonder if you can help me with a draw for the power circuit on Verboard I been waiting for the draw to start building it
Curious why you are wanting to build it if you had one working though
It uses a 78M05 regulator which is not as immune to automotive voltage spikes as the transistor would be,.
Just so you know. That was a concern with longevity of the repair product.because of that kris said
Would putting the diode on the negative side be an acceptable solution?Right, a 78M05 is fine for testing using a power supply, but if you want to put it in a car, a transistor will be better at withstanding the surges and spikes.
It would be even better to add reverse polarity protection by inserting a UF4007 diode between the +12V from the car and the transistor's collector and the resistor, but that would mess up your nice layout because the antenna coupling capacitor should go straight to the car's +12V, which would not connet to the transistor's collector any more.
Well... I hate to bust your bubble but...will for now I'm going to build my own FM transmitting so i'll start from zero
thus I wonder if you can help me to build a good power supply circuit for the transmitting and a good FM transmitting circuit that work on line in
I don't think that's a good idea. I think it would be best to keep the 0V rail at chassis voltage.Would putting the diode on the negative side be an acceptable solution?
Building the power supply before you have an actual circuit made could very well end up requiring that you build another. These things are planned out completley before they are built.
That and. Building your own FM transmitter is not a task that will fly by in 30-minutes.
Consider if this is worth it to you. This will require more time invested in design and building your circuit (although examples can be found online, you will most likely need to tweak them for your purpose).
A new FM transmitter with a line-in can be bought extremely cheaply. I would personally rather buy a $15-$20 FM transmitter than spending any more than 2 hours on making my own.
If this is a project you want to tackle for academic reasons, we will help you learn. I personally will not be drawing a bunch of stripboard layouts to get this project done, but I will help you in getting your own drawn out so you can learn how to do this in the future with other projects.
If this project is to 'save' you some money... I hate to say it, but a DIY FM transmitter will be more expensive than buying an entry level model once you account for the time you will put into it.
Let us know
I'll build this one and use line in rather than the mic
but I wonder if there's any enhancement you advice me to do for it
thank a lot KrisBlueNZHere's the power supply with the diode added. This circuit has an output of about 5V. If your FM transmitter circuit needs a different voltage, you'll need to change D1 to a zener diode with a different voltage - its zener voltage should be about 0.6~0.7V higher than the output voltage you want.
Zener diodes are only available with certain nominal voltages. If you use a transmitter that's designed to run from a 9V battery, you would have to choose between a 9.1V zener and a 10V zener. I would use a 9.1V zener: http://www.digikey.com/product-detail/en/1N5239BTR/1N5239BFSCT-ND/1532769
I can't help with the rest of the circuit I'm afraid. RF is not my thing.
what do you mean with unstable frequency in the video it use trimmer capacitor to control the frequency..do you mean that the frequency will keep changing??you will find that one very unstable frequency wise
for one to be transmitting music you need one that has a PLL ( Phase Locked Loop) system
and that immediately makes the circuit much more complex.
I appreciate you want to learn to build things and that's awesome....
but you should start with circuits a bit more basic
Dave
I seethere is nothing to keep the freq stable and on the required freq, it will drift all over the place
specially with varying voltage, temperature and just by moving your hand near it
that is why they use crystal locked oscillators and associated PLL circuits to keep the freq stable
