Binary Counter
Egor
Nov 12, 2014
27
Hello!
Stuck with the simulations again. I'm trying to simulate a binary counter using CD4516. I get an error upon trying to run the simulation, can you guys please help me find the issue?
Harald Kapp
14,289
It seems that you don't have a model (subcircuit) for the CD4516B. As far as I know, LTSPICE doesn't include this model. You need to find one or create it on your own.
Egor
Nov 12, 2014
27
I downloaded a large model library from here: http://ltwiki.org/?title=Components_Library_and_Circuits
I tried using 74HC-something counter, but got a similar error. I have no idea how to even start creating my own models. How can I know if a model that is searchable through LTspice will work? Maybe I have a different counter.
EDIT:
http://i.imgur.com/Vk0rFEF.png
I can edit this component through LTspice, doesn't this mean I have the model?
Harald Kapp
14,289
The data your screeenshot shows doesn't make sense. I do not want to download the full library. Can you extract the model for the 4516 from the library andupload it as text file here? I could then have a look at it.
Egor
Nov 12, 2014
27
I have two of those
Version 4
SymbolType CELL
LINE Normal -80 32 -80 464
LINE Normal 80 32 -80 32
LINE Normal 80 464 80 32
LINE Normal -80 464 80 464
LINE Normal -80 320 -112 320
LINE Normal -80 128 -112 128
LINE Normal -80 96 -112 96
LINE Normal -80 160 -112 160
LINE Normal -61 160 -80 169
LINE Normal -80 150 -61 160
LINE Normal 80 416 112 416
LINE Normal -80 352 -112 352
LINE Normal -80 384 -112 384
LINE Normal -80 416 -112 416
LINE Normal 80 384 112 384
LINE Normal 80 352 112 352
LINE Normal 80 320 112 320
LINE Normal 80 256 112 256
LINE Normal -80 192 -112 192
LINE Normal -79 224 -112 224
WINDOW 3 -48 480 Left 0
WINDOW 0 -14 17 Left 0
SYMATTR Value CD4516B
SYMATTR SpiceLine VDD=5 SPEED=1.0 TRIPDT=5e-9
SYMATTR Prefix X
SYMATTR SpiceModel VDD 0
SYMATTR Description 4 bit binary up/down counter with asynchronous reset and preset
PIN -112 96 LEFT 38
PINATTR PinName _CIN
PINATTR SpiceOrder 1
PIN -112 128 LEFT 38
PINATTR PinName U_D
PINATTR SpiceOrder 2
PIN -112 192 LEFT 38
PINATTR PinName PE
PINATTR SpiceOrder 3
PIN -112 160 LEFT 50
PINATTR PinName CLK
PINATTR SpiceOrder 4
PIN -112 320 LEFT 38
PINATTR PinName P1
PINATTR SpiceOrder 5
PIN -112 352 LEFT 38
PINATTR PinName P2
PINATTR SpiceOrder 6
PIN -112 384 LEFT 38
PINATTR PinName P3
PINATTR SpiceOrder 7
PIN -112 416 LEFT 38
PINATTR PinName P4
PINATTR SpiceOrder 8
PIN 112 320 RIGHT 36
PINATTR PinName Q1
PINATTR SpiceOrder 9
PIN 112 352 RIGHT 36
PINATTR PinName Q2
PINATTR SpiceOrder 10
PIN 112 384 RIGHT 36
PINATTR PinName Q3
PINATTR SpiceOrder 11
PIN 112 416 RIGHT 36
PINATTR PinName Q4
PINATTR SpiceOrder 12
PIN 112 256 RIGHT 36
PINATTR PinName _COUT
PINATTR SpiceOrder 13
PIN -112 224 LEFT 36
PINATTR PinName RESET
PINATTR SpiceOrder 14
Version 4
SymbolType CELL
LINE Normal -80 299 -80 464
LINE Normal 80 464 80 299
LINE Normal -80 224 -112 224
LINE Normal 80 299 -80 299
LINE Normal -48 272 -48 299
LINE Normal -80 272 -48 272
LINE Normal -80 32 -80 272
LINE Normal 48 272 48 299
LINE Normal 80 272 48 272
LINE Normal 80 32 80 272
LINE Normal 80 336 -80 336
LINE Normal 80 368 -80 368
LINE Normal 80 400 -80 400
LINE Normal 80 432 -80 432
SYMATTR Prefix X
PIN -112 96 LEFT 38
PINATTR PinName U_D
PINATTR PinName PE
PINATTR PinName CLK
PINATTR PinName P1
PINATTR PinName P2
PINATTR PinName P3
PINATTR PinName P4
PINATTR PinName Q1
PINATTR PinName Q2
PINATTR PinName Q3
PINATTR PinName Q4
Harald Kapp
14,289
Sorry, these are only the descriptions for the graphic symbol. These are required for drawing the schematic, but not for the simulation.
I should have made myself more clear. What you are looking for (and hopefully will find) is something that looks like:
Code:
.subckt NE555 1 2 3 4 5 6 7 8
A1 N001 2 1 1 1 1 N003 1 SCHMITT Vt=0 Vh=1m
R1 N001 1 5K
R2 5 N001 5K
R3 8 5 5K
S1 1 7 N007 1 D
A2 N011 N003 1 1 1 1 N008 1 SRFLOP Trise=100n tripdt=10n
A3 6 5 1 1 1 1 N012 1 SCHMITT Vt=0 Vh=1m
S2 8 3 N009 1 O
S3 3 1 1 N009 O
A6 1 N006 1 N008 1 1 N007 1 OR Ref=.5 Vlow=-1 Trise=100n
R7 8 1 4K
R9 2 1 1G
R10 6 1 1G
A4 1 N008 1 N006 1 N009 1 1 OR ref=.5 Vlow=-1 Trise=100n
A5 4 1 1 1 1 N006 1 1 SCHMITT Vt=.7 Vh=1m
D1 4 1 DR
A7 1 N006 1 N012 1 1 N011 1 OR
D2 8 4 400uA
.model DR D(Ron=150K Roff=1T Vfwd=1.6)
.model O SW(Ron=6 Roff=1Meg Vt=0 Vh=-.8)
.model D SW(Ron=6 Roff=.75G Vt=.5 Vh=-.4)
.model 400uA D(Ron=1K Ilimit=400u epsilon=.5)
.ends NE555
This is the functional description (here for an NE555) that can be simulated. Such a description for the CMOS counter is required.
Egor
Nov 12, 2014
27
Um... I don't really know what I'm looking for, sorry. All I have in the LTspice libraries are symbol files. I can't find anything other than that for *4516 (or *4538 for that matter, that's a monostable vibrator, but this model I can simulate). What is the format of the file I'm supposed to find?
EDIT I guess the file type is .sub? But I can't find .sub's for half the stuff I have already simulated... I'm kinda lost here. Why are simulation programs so god damn not user-friendly?
Harald Kapp
14,289
LTSPICE names these fils *.sub, but that is not mandatory. These are simple text files and can have any extension - as long as you tell LTSPICE the full filename+extension.
If there is a subcircuit for the 4516 in one of the libraries, then you should find it by using the search function of your operating system or simply loading the library files into a text editor and using the editor's search function.
On my windows 7 I can search all files within a directory on the command line using:
Code:
grep 4516 *
which will scan all files (*) for the string "4516".
Egor
Nov 12, 2014
27
I tried searching using the regular windows search function, I came up only with symbol files. But the thing is, I simulated 4538 a couple of weeks ago, I tried searching for this and still haven't found any sub files, so how the hell did I simulate it?
Harald Kapp
14,289
The file is not necessarily named .sub, it may be .lib or something different.
On windows 7:
  • go to the folder where the library files are located.
  • open a command line window there. You can Shift+right click on the folder name and select "open command window" or similar from the contect menu (sorry, my GUI is German, I can't tell you what the entry is exactly in English).
  • a new window should open showing only a command prompt (on my computer this would be "C:\Program Files (x86)\LTC\LTspiceIV\lib\sub>")
  • type: "grep ends *" without the hyphens, press return. This should give you a list of files that contain subcircuits.
  • repeat, typing "grep 4516 *". This will show ou which file, if any, contains teh subcircuit for the 4516.
You may have to search several directories where library files are stored.
Laplace
Apr 4, 2010
1,252
Code:
grep 4516 *
I tried doing that on my Windows 7 but it did not work:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Laplace>grep
'grep' is not recognized as an internal or external command,
operable program or batch file.
Egor
Nov 12, 2014
27
"grep" doesn't work, at least not on 8.1. Says it's not a command or something like that.
Harald Kapp
14,289
Right, sorry again. grep is a unix utility that is not normally part of Windows. It's on my computer as component of another software installation.
You can use the evaluation version of wingrep, grepwin or any other port of grep to Windows.
Egor
Nov 12, 2014
27
While I'm doing all of that, does anybody here have a model for ANY up/down binary counter? I simply need to simulate clock against all of the outputs and I'm done... Instead of actually learning something I'm headbutting with software. Bullshit :(
Harald Kapp
14,289
SPICE (any flavor of it) is an analog simulator. LTSPICE does incorporate some basic digital functions, but it is not a full-fledged digital simulator. If you're only looking for the relation of outputs to clock, Google "binary counter simulator" and you will be rewarded with online simulators that show you this behavior.
Egor
Nov 12, 2014
27
I need to simulate 2 circuits for my laboratory assignment that is due in two days. I can't pick any random counter simulation off the net because I need to make a few changes to it with a CD4538 for the second simulation,. I just need a working model so I can actually start doing something today.
Harald Kapp
14,289
NXP offers SPICE models here (al models (zip)).
I haven't tried these, but the syntax looks like regular SPICE to me. You will have to unzip the files and store them in a location that is accessible to you and LTSPICE.
There is a ressource (Adding new components to LTSPICE) that explains how to use such models in LTSPICE. You will have to create your own schematic symbols, read the ressource for a how-to.
Egor
Nov 12, 2014
27
Eh... well, thank you for your help :) I don't want to spend additional hours trying to add the model, since I can see that I don't understand what this guide wants from me and where to start.
I guess I'll have to compromise with the prof somehow...
PS: Found a PSpice model library sitting in LTspice, it has 4516 in it. Doesn't help though... I tried simulating 4516 in PSpice with this library, it says "Undefined" model. Fing great.
D4516B DUAL UP-COUNTERS
* THE CMOS INTEGRATED CIRCUITS DATABOOK, 1983, RCA
* KN 9-9-92 REMODELED USING LOGICEXP, PINDLY, CONSTRAINT DEVICES
.SUBCKT CD4516B PS_EN_I RESET_I CLOCK_I UP/DOWN_I CINBAR_I P1_I P2_I P3_I P4_I
+ COUTBAR_O Q1_O Q2_O Q3_O Q4_O
+ OPTIONAL: VDD=$G_CD4000_VDD VSS=$G_CD4000_VSS
+ PARAMS: MNTYMXDLY=0 IO_LEVEL=0
UCD4516BLOG LOGICEXP(13,27) VDD VSS
+ PS_EN_I RESET_I CLOCK_I UP/DOWN_I CINBAR_I P1_I P2_I P3_I P4_I Q1 Q2 Q3 Q4
+ PS_EN RESET CLOCK UP/DOWN CINBAR P1 P2 P3 P4
+ COUTBAR T2 T3 T4 PRESET1 PRESET2 PRESET3 PRESET4 RESET1 RESET2 RESET3 RESET4
+ U1 U2 U3 U4 CLK CIN
+ D0_GATE IO_4000B IO_LEVEL={IO_LEVEL}
+ LOGIC:
* BUFFER:
+ PS_EN = { PS_EN_I }
+ RESET = { RESET_I }
+ CLOCK = { CLOCK_I }
+ UP/DOWN = { UP/DOWN_I }
+ CINBAR = { CINBAR_I }
+ P1 = { P1_I }
+ P2 = { P2_I }
+ P3 = { P3_I }
+ P4 = { P4_I }
* INTERMEDIATE TERMS:
+ RESETBAR = { ~RESET } ; UP/DOWN&Q2 AND UP/DOWN|Q2 CAN MINIMIZE
+ U1 = { ~(Q1 ^ UP/DOWN) & ~CINBAR }
+ U2 = { (UP/DOWN & Q2 & Q3 & Q4) | ~(UP/DOWN | Q2 | Q3 | Q4) }
+ U3 = { (UP/DOWN & Q2) | ~(UP/DOWN | Q2) }
+ U4 = { (UP/DOWN & Q2 & Q3) | ~(UP/DOWN | Q2 | Q3) }
+ CIN = { ~CINBAR }
* OUTPUT ASSIGNMENTS:
+ CLK = { ~(CLOCK | RESET | PS_EN) }
+ PRESET1 = { RESET | ~PS_EN | ~P1 }
+ PRESET2 = { RESET | ~PS_EN | ~P2 }
+ PRESET3 = { RESET | ~PS_EN | ~P3 }
+ PRESET4 = { RESET | ~PS_EN | ~P4 }
+ RESET1 = { RESETBAR & (~PS_EN | P1) }
+ RESET2 = { RESETBAR & (~PS_EN | P2) }
+ RESET3 = { RESETBAR & (~PS_EN | P3) }
+ RESET4 = { RESETBAR & (~PS_EN | P4) }
+ COUTBAR = { ~(U1 & U2) }
+ T2 = { U1 } ; T1 = CINBAR
+ T3 = { (U1 & U3) }
+ T4 = { (U1 & U4) }
U1 JKFF(1) VDD VSS PRESET1 RESET1 CLK
+ CIN CIN Q1 Q1BAR
+ D0_EFF IO_4000B
U2 JKFF(1) VDD VSS PRESET2 RESET2 CLK
+ T2 T2 Q2 Q2BAR
+ D0_EFF IO_4000B
U3 JKFF(1) VDD VSS PRESET3 RESET3 CLK
+ T3 T3 Q3 Q3BAR
+ D0_EFF IO_4000B
U4 JKFF(1) VDD VSS PRESET4 RESET4 CLK
+ T4 T4 Q4 Q4BAR
+ D0_EFF IO_4000B
UCD4516BDLY PINDLY (5,0,9) VDD VSS
+ Q1 Q2 Q3 Q4 COUTBAR
+ CLOCK CINBAR RESET PS_EN P1 P2 P3 P4 UP/DOWN
+ Q1_O Q2_O Q3_O Q4_O COUTBAR_O
+ IO_4000B MNTYMXDLY={MNTYMXDLY} IO_LEVEL={IO_LEVEL}
+ PINDLY:
+ Q1_O Q2_O Q3_O Q4_O = {
+ CASE(
+ CHANGED(RESET,0) | CHANGED(PS_EN,0), DELAY(-1,210NS,420NS),
+ CHANGED_LH(CLOCK,0), DELAY(-1,200NS,400NS),
+ DELAY(-1,211NS,421NS) ;DEFAULT
+ COUTBAR_O = {
+ CASE(
+ CHANGED(RESET,0) | CHANGED(PS_EN,0), DELAY(-1,320NS,640NS),
+ CHANGED_LH(CLOCK,0), DELAY(-1,240NS,480NS),
+ CHANGED(CINBAR,0), DELAY(-1,125NS,250NS),
+ DELAY(-1,321NS,641NS) ;DEFAULT
+ FREQ:
+ NODE = CLOCK
+ MAXFREQ = 2MEG
+ WIDTH:
+ NODE = CLOCK
+ MIN_HI = 150NS
+ MIN_LO = 150NS
+ WIDTH:
+ NODE = RESET
+ MIN_HI = 220NS
+ MIN_LO = 220NS
+ WIDTH:
+ NODE = PS_EN
+ MIN_HI = 220NS
+ MIN_LO = 220NS
+ SETUP_HOLD:
+ DATA(1) = CINBAR
+ CLOCK LH = CLOCK
+ SETUPTIME = 130NS
+ HOLDTIME = 60NS
+ WHEN = { PS_EN!='1 & RESET!='1 }
+ SETUP_HOLD:
+ DATA(1) = UP/DOWN
+ CLOCK LH = CLOCK
+ SETUPTIME = 360NS
+ HOLDTIME = 30NS
+ WHEN = { PS_EN!='1 & RESET!='1 & CINBAR!='1 }
+ SETUP_HOLD:
+ DATA(1) = PS_EN
+ CLOCK LH = CLOCK
+ RELEASETIME_HL = 150NS
+ SETUP_HOLD:
+ DATA(1) = RESET
+ CLOCK LH = CLOCK
+ SETUP_HOLD:
+ DATA(4) = P1 P2 P3 P4 ; CHECK SETUPTIME PS_EN TO Pn
+ CLOCK HL = PS_EN
+ SETUPTIME = 70NS
+ WHEN = { RESET!='1 & CINBAR!='1 }
+ MESSAGE = "SETUPTIME PRESET_ENABLE TO Pn TOO SHORT"
+ SETUP_HOLD:
+ DATA(4) = P1 P2 P3 P4 ; CHECK HOLDTIME PS_EN TO Pn
+ CLOCK LH = PS_EN
+ HOLDTIME = 25NS
+ MESSAGE = "HOLDTIME PRESET_ENABLE TO Pn TOO SHORT"
.ENDS
Arouse1973
Adam
Dec 18, 2013
5,178
I think you need to include the CMOS library on your simulation. Your path name and library name might be different to mine but the procedure is the same. The first picture is with the same error as you, the second is with the directive statement above the IC and now it works.
Adam
