Hi.
I have a Nuvoton NUC123 microcontroller, it runs an ARM cortex M0, and it came on a developement board (NUC123 SDK) which contains a 12 MHz crystal.
It recently started freezing every other time upon reset, and in the debugger I saw that it is stuck in a while loop, waiting for the external 12 MHz clock source to become stable.
After a while it stopped starting at all, always freezing on that same line. So I thought maybe the crystal was damaged, so I removed it and soldered a new crystal and, voila! it worked. However after a while it stopped working again with the same problem as before.
My question is: Does anyone have a guess at what's been happening? Is the chip damaged? was the crystal damaged at all?
Does anyone know of a way to test a crystal if it's broken? I have a 2 Mega Samples Per Second oscilloscope at my disposal.
And also, does anyone know how do microcontrollers usually decide whether or not a clock source is stable?
The tech support of Nuvoton haven't answered me yet to these questions, so I'm asking in this forum.
In terms of what I've been doing with the board:
I connected a self made 3.3V UART to +-7V RS232 converter (it might have electrocuted the board?), but during the period between the soldering of the second crystal and the chip freezing again I didn't use the converter.
And I also worked quite a bit with its USB.
I also soldered pins to the board to gain access to the pins of the microcontroller.
I made my best to prevent ESD, by working with an ESD protection bracelet.
I would buy a new board, but I need to know what the cause was so that I don't repeat the same error again.
So that's it. anyone can help?
