crashdodson
- Jan 12, 2015
- 7
- Joined
- Jan 12, 2015
- Messages
- 7
Please excuse my ignorance on the topic of electricity/electronics. I have a project I am working on using RGB LED light strips. The light strips are powered by a mini controller that receives 12vDC. The output from the controller are RGB grounded connections and one 12V DC connection. As I understand the light strip is common anode so the RGB share a common 12V connection. I don't quite understand PWM but I don't think I need to for my project. If I apply 12V DC to the light strip and ground either the Red, Blue, or Green portion of the strip, it will light just that color at full brightness.
I need a very small normally-open relay (I think) to bypass the controller and just provide 12V DC to the LED strip and ground the Red LED's only when a second 12V source is energized. I have found a 14 pin DPDT relay that would accomplish my goal but it is too large for my application. I could even relay each of the wires RBG and +12 individually if I could find very small inline relays. When the second 12v source is energized and the relay is activated I need to maintain power/input to the controller, just cut its output. Please see my bad drawing.
I have been trying to find relays like the ones in the picture but I have been unable to locate anything like them. I could also do this with some sort of PCB if I could find one small enough. Thanks in advance for any help/advice.
