Which component is of the wrong value?
charmcaster.engg
Mar 20, 2014
79
Which component is of the wrong value? n why? Answer is given as R1.
Gryd3
Jun 25, 2014
4,098
Call me picky, but I suggested you posted your last topic in 'Homework Help'
This certainly seems like it would fall in that category as well.
...As does all of your other topics.
I will not do your homework for you. Please reply with the work you have done so far on this problem.
charmcaster.engg
Mar 20, 2014
79
I have calculated equivalent resistance which comes out to be 480. Thus current comes out 0.1A. Then power comes 4.8W. But wattmeter shows 9.408 reading?
Gryd3
Jun 25, 2014
4,098
Perfect. Do take a look at the Ammeters in the drawings to see which part of the circuit is behaving properly.
Gryd3
Jun 25, 2014
4,098
Should I find out the loop currents by applying KVL,KCL
Yes. Ignore the readings on the ammeters and wattmeter until you have completed some of your calculations.
If the printed values match your calculations then you can state the components function correctly. Otherwise you know where the faulty component is.
