What is the analog output for the input code 0101.
charmcaster.engg
Mar 20, 2014
79
A 4-bit R/2R digital-to-analog (DAC) converter has a reference of 5 volts. What is the analog output for the input code 0101.
I calculated one step voltage as 5/16=0.3125. How to do it further?
Gryd3
Jun 25, 2014
4,098
What is the integer value of the binary number '0101' ?
(It's a number between 0 and 15 ;))
Once you know this, I'm sure the next step will click in.
Gryd3
Jun 25, 2014
4,098
The answer goes wrong.Then how to do it?
What are you getting for an answer?
1.5625 V
or 1.66 V
Think about what the 0000 is... it's a 0
1111 is 15 ..
So how many steps from 0 to 15?
0 must output 0V, 15 must output 5V... so 5 must output ??V
charmcaster.engg
Mar 20, 2014
79
1.5625 V
or 1.66 V
1111 is 15 ..
If 15 is 5V then 0101 is 1.66V. Then I multiply it with resolution to get 0.5187. Is it right?
Gryd3
Jun 25, 2014
4,098
I think you got a little side-tracked on this.
You have a 5V 4-bit DAC.
So we can determine the resolution in % or volts.
4-bit = 16 combinations. (or 15 steps)
1 / 15 steps = 6.66%
5V / 15 steps = 0.33V
So if we need to determine the output at '0101', we take the integer value which is 5, and multiply is by the resolution.
0.33V * 5 steps = 1.66V
6.66% * 5 steps = 0.33% ( 33% of 5V, is 1.66V )
charmcaster.engg
Mar 20, 2014
79
Thanks!
