I need to replace this well-worn connector and its pins. There is no part list that identifies the connector. I've tried at length to figure out who made/makes this part, with no luck.
You can see by the closeup photos that the pins are made from flat metal that is bent back on itself to form a sort of compressible contact. The housing has a tab with an apparent screw hole and little tabs/feet on the opposite side. It's very roughly about an inch square in Length/Width and about 3/8 inch or less in height.
Does anyone here have an idea who made/makes this? Any insights would be appreciated!!
