Audisturbo1
- Apr 15, 2015
- 13
- Joined
- Apr 15, 2015
- Messages
- 13
I am having trouble with this and am looking for a simple solution to my problem, I have a single battery supplying 2 switching voltage regulators, the output on each regulator is 12v, 3 amps. I have them wired in parallel as the load requires 12v. The key is I need redundancy so if one voltage regulator fails the other will continue to supply power.. What I am trying to accomplish is adding 2 leds to indicate a failure, 1 for each voltage regulator to indicate that this regulator Is working and outputting 12v. If I see one of these LEDS turn off I know that corresponding voltage regulator Is no longer functioning. Can anyone help me out with this?
I have attached a simple circuit diagram Minus the indicator LEDs. I already have 12v LEDS on hand.
Thank you!
Jason
Thank you!
Jason
