Please can anyone tell me what exactly it means to say voltage leads current or current leads voltage???
No, that's not the issue. If it were proportional, we're dealing with a resistive circuit where current neither leads nor lags voltage but has the same phase.by saing "leads" you mean is proportional right ?
Thank you signalman....got the point.....but still in a capacitor current leads the voltage....does it mean that even before you apply voltage ,current will be present.....??
When you see the graph of a capacitor's voltage vs.current graph, u see that at time=0, voltage is zero...but current has certain value that is not equal to zero...what does that mean?
To answer your question re lead/lag in capacitors and inductors picture this. You have a capacitor (discharged), a switch and a power supply. Connect capacitor via switch to power supply plus and other terminal of capacitor to power negative. When you switch on the capacitor will "seem" like a "short circuit" to the power supply and draw a large current(depends on cap size etc) and the voltage measured across the capacitor will be (ideally) zero. As the capacitor charges up the current will drop and the voltage will increase to full supply volts. So if you measure capacitor current and capacitor voltage you will note that the current is at a maximum and voltage is at a minimum at the instant of switch on. So we say that the current "leads" the voltage by some phase angle(ideally 90 deg).
With inductor opposite happens. Replace cap. with inductor and switch on. Full supply voltage appears across inductor and current will flow. However, the magnetic field generated by the current will generate a "opposing" voltage to the applied voltage due to "self inductance" and this will "slow" full current build up (depends on inductor etc). So if you measure voltage across inductor it will be there as soon as switched on and current measurement will show a slow build up till steady state is reached. So we say that the current "lags" the voltage by some phase angle (ideally 90 deg).
Signalman has given a good explanation.
Ratch, you are correct in your statement retransient response vs repetitive cycles. But the reasoning applies if you are able to at some increasing rate using a suitable switch alternately "charge" and "discharge" said components. Measuring volts across the components and current through them (with suitable component values) one will be able to see (and measure) the difference between volt and current.Of course if you then use the volts as reference there will be a "lead" "lag" of current.
I use this example as (hopefully) a simple example of this effect without going into great mathematical detail.
As far as using "charge" for a capacitor that is what is understood by most people.
A capacitor "energised" as you put it to some high voltage is not one I would care to contact even if the "net charge" is zero because electrons have been gathered on one side and sucked out of the other!
I don't believe I've ever seen the topic of "capacitor accumulation/depletion current" discussed in any circuit theory textbook. Do you have a reference where it is explained?...the same accumulation/depletion current...
I don't dispute your description; however, it is not a very useful concept for doing circuit analysis where we like to pretend that current flows through the capacitor.I believe it is more correct than most other descriptions
