vanillasnake21
- Apr 20, 2015
- 16
- Joined
- Apr 20, 2015
- Messages
- 16
Hey I've built an LED light for my aquarium as a supplement to my existing light but I'm having some issues with it. The light runs fine, but I noticed that the first LED that I'm powering is significantly more brightly lit then the last one, the middle 2 are in between. I'm using Cree XT-E Cool White/Soft White combo (3 of each). I built a driver by using LM317. I have a 1 ohm resistor running from control pin to the out pin, then I just ran a single wire from the outpin to all the + on the led, and ran a single wire through the - and into ground. Is this the right way to do it? Just to save you trouble here are the specs for the LED:
wattage:
2.1w (700mA), 3.1w (1,000mA), 5w (1,500mA)
max drive current:
1500mA
forward voltage:
3.0v (700mA), 3.15v (1,000mA), 3.3v (1,500mA)
Thanks!
wattage:
max drive current:
1500mA
forward voltage:
Thanks!
