connecting LEDs in series
adel2014
Dec 1, 2013
22
hello every body , Greetings from Egypt , i am going to do a LEDs signs for cars using a SMD leds as showing , and i was asking Why i can not connect LEDs in series with out resistor , the supply is 12V and the number of LEDs in series is 6 , so every LED will take 2V - in the safe zone - , why i must put a resistor
Colin Mitchell
Aug 31, 2014
1,416
Provide evidence of exactly what type of LED you are using.
You can make a BIG mistake.
Please check out this, it will answer all of your questions and then some. Anything you don't understand, just ask :)
ramussons
Jun 10, 2014
475
For your simplistic understanding:
LED's don't behave like resistors - they don't follow i=v/r.
Once they light up, the variation of current is very large for a small variation of voltage making it practically impossible to control the current and limit it to avoid a burnout.
So you use a suitable resistor to limit the current or use a current source instead of a voltage source.
PRIYADHARSHINI
Feb 6, 2014
137
First You just check out your LED colour.each colour has different forward voltage(Vf).and you decide your forward current (If)...it depends upon your brightness level.
for example R (curent limiting resistor) = (Vs - (Total Vf of all 6 series LED)/If
