Component ID
Martaine2005
May 12, 2015
5,314
Hi guys, I have been scavenging components from an old dvd player board smps.
Two components look exactly like a standard through hole transistor. Black with the flat front But only have two legs..
They each have the markings N5S and N25S. Google wasn't my friend today..
Could they possibly be Diodes?
The boards silk screen shows a standard transistor except the flat line is twice as thick as the circular section. And has only two holes.
Thanks in advance. Martin.
Arouse1973
Adam
Dec 18, 2013
5,178
Hi
Would you say this looks the same size as a TO-92 type signal transistor or is it much larger?
Adam
Martaine2005
May 12, 2015
5,314
Thanks Adam, I would say the same size as a TO-92.
About 5mm long and 4.5 - 5mm across the flat section. (just the body)...
Arouse1973
Adam
Dec 18, 2013
5,178
Packages like this could be a number of components like a varactor diode, reference diode of SIDIAC. Couldn't find anything either with the device numbers you gave. Sorry.
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
Don't throw them away just yet, someone else might know what they are!
Adam
Martaine2005
May 12, 2015
5,314
Ok Adam, I will put them in my container for now.
But if you don't know what they are, then a noob like me will never use them..
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Martin, why not whip out your VOM and do some tests on it before throwing it away? Heck, it could even be an infrared photo-diode (depending on where you removed it from) since many of these "see" through black plastic. And you won't be a noob forever. Lay it aside if you can't make sense of it now. Maybe more information will appear later from another tear-down you perform. Can you post a happy-snap of this thing and a close-up of the where you removed it from the board? Maybe someone here will recognize it.
Hop
Martaine2005
May 12, 2015
5,314
Sure Hevans1944, thanks. It was a dvd player switch mode power supply so infra red diode very unlikely....
I will post a pic of the said items and board tomorrow. Have to work out how to post a pic!!
Arouse1973
Adam
Dec 18, 2013
5,178
Easy. Take Pic, compress it to 100Kb save on your PC. Goto upload file in the thread box you are typing in. Its down the bottom. Click full image, job done.
Martaine2005
May 12, 2015
5,314
No. well yes, but only office 2003. I'll have a quick look online for something.
Martaine2005
May 12, 2015
5,314
The 114 is size comparison only. The other has N25S and same size.
@ Adam. windows live does it too..
Martaine2005
May 12, 2015
5,314
Sorry Adam, I quoted at the bottom of the pics that the three legged 114 1431A was for size comparison only.
I believe it to be a TO-90 package.
Oops, TO-30
Martaine2005
May 12, 2015
5,314
No problem. It's still a good way to learn.. I learnt how to re-size a photo from my usb microscope.
Gotta love this forum! If only these forums were around in '84' when I failed my part two electronics on maths.
