Robert Hill
- Mar 5, 2015
- 112
- Joined
- Mar 5, 2015
- Messages
- 112
Hi all,
I've been learning about current sources and tried to make a simple one as a practice.
I followed the design 2.21 on page 72 of the 2nd edition of the art of electronics.
Essentially I have a 5v VCC going into a standard LED (the load) and then the negative lead of the LED goes into the collector of an NPN transistor. The base of the transistor is biased by a 3.3v supply through a 10ohm resistor. The emitter of the transistor goes to ground through a 1k resistor. By my calculation I should get a current of 2.7miliamps through the LED ( 2.7v/1000Ohms =0.0027 amps)
This is verified when I build the circuit in the free software 'circuit simulator'.
However when I built the circuit in real life I got 3.4 miliamps through the LED. This seemed to be basically the same as if I ran the LED from 5v supply in series with a couple of hundred ohm resistor.
Can anyone help me understand why this is or if I've gone wrong somewhere? It is to do with the unreliability of components such as resistors having 5% inaccuracy in their ratings or perhaps it is the transistor I am using?
Any help appreciated.
Thanks,
Thanks,
