Low frequency FET response, determining f[sub]L[/sub] of Cs capacitor
nvjnj
Sep 13, 2014
11
I'm trying to get the low frequency cutoff value of the capacitor Cs of the following ac equivalent circuit using the equation:
f(L)=1/(2*pi*Req*Cs)
To do this, I'm supposed to reduce the circuit "seen" by capacitor Cs to an equivalent RC circuit where Req would be the equivalent resistance seen by Cs.
Employing Thevenin's Theorem, open-circuiting all current sources and short circuiting all voltage sources gives me the equivalent resistance as:
Req=RS||((RL||RD)+rd) which simpifies into the equation:
Req=RS/(1+(RS/(RDRL+rd)))
But the real equation stated in the internet and text books is:
Req=RS/(1+(RS(1+gmrd)/(RDRL+rd)))
So, I am missing the factor (1+gmrd) in my equation. Please help me figure out what I am doing wrong.
there is a current source there which is a dependent current source. You can't just open circuit that.
nvjnj
Sep 13, 2014
11
I see....I missed that.
Thanks....I'll try to redo it
Okay, so I tried doing it by not removing the dependent current source. But I'm still not getting the answer. These are the steps I followed:
Req=V(open-circuit)/I(short-circuit)
V(open-circuit):
Open circuiting Cs, Voltage across this open circuit is equal to voltage across Rs. Voltage across Rs = Is*Rs, where Is is the current flowing through Rs.
Is=(rd/(rd+(Rs+RD||RL)))*gmVgs
Therefore V(short-circuit)=(rd*Rs/(rd+(Rs+RD||RL)))*gmVgs
I(short-circuit):
Short circuiting Cs would make Rs redundant and is removed. Hence current accross this path is:
Is=(rd/(rd+(RD||RL)))*gmVgs
Hence Req=(rd*Rs/(rd+(Rs+RD||RL)))*gmVgs / (rd/(rd+(RD||RL)))*gmVgs
This eliminates my gm terms, which is required in the final equation as stated in the original post. Please tell me what I am doing wrong?
Why did you calculate V(short circuit)?
