have designed my own CT(ferrite core coil) with just 30 turns, bcuz of lesser primary current about 0.1A, does it have any drawbacks in long run. thanks for your replyLess turns = higher secondary current
More turns = less secondary current
Where do you take the magic number 100 from? You can have current transformers with widely varying turns ratios, depending on your application.
What are you thinking of?does it have any drawbacks in long run
how to calculate impendance by no of turns, can u give me an example of it. thanksThe number of turns affects the impedance of the transformer secondary. This should be considerably higher than the load resistance. I expect that you are using a high frequency if you have a ferrite core.
