Martaine2005
- May 12, 2015
- 5,276
- Joined
- May 12, 2015
- Messages
- 5,276
Blimey. I sounded a little like Colin there...
Before I answer , ordinary HSS drill bits?Back in the last century, when I first started making circuit boards, it didn't take five minutes to realize that ordinary HSS drills didn't cut it for drilling fiberglass board
Good ol' trial-and-error will usually lead you to the "right" speed that works for you
I am really glad to point this conversation back to to me.
That was a hefty read . But what happened.?
I don't think zealous is the proper description; just practical.... Hop you are being a little zealous
If you have a technique or tool for sharpening those tiny (sub-millimeter diameter) drill bits, please share! I once worked with a machinist who could sharpen most anything by hand, aided only by his trained and experienced Mark I Eyeball, but I never master that process except maybe for wood lathe chisels.... I am very finicky and do not let any of my cutting tools dull.
They are all kept sharp and clean. So I probably would never have noticed.
When I was carpet fitting, even the stanley blades we used were constantly sharpened on a stone on our belt.
They lasted weeks as opposed to minutes.
That made me chuckle Hop.but don't try to fly with one.
I am talking Transportation Safety Administration (TSA), those friendly folks who keep people from carrying on stuff that might be used as a WMD or worse... provided it isn't carried on in underwear.Are you talking US customs?
I still have mine, purchased in the late 1970s ~$400. Precision machined cast iron & steel. Made in Japan. Height=16" shown next to a Dremel Tool for comparison. I added the clamp bar to the base. This stays on the shelf except for special drilling jobs. As far a I can tell nobody still makes these.However, it was the breakage problem when free-hand drilling that led my laboratory supervisor to approve the purchase of a table-top drill press with a high speed motor and an accurate spindle with precision bearings and very little runout. IIRC, back then (mid 1970s) they cost less than five hundred dollars, but not much less.
Hey Everyone!
I wonder if you guys could tell me what you use to drill your homemade PCBs with (like what drill press you use/where you get your drill bits).
I started drilling a PCB I made but after a only few holes, the drill bits snapped. I think that it may be because the drill press I'm using isn't very precise and has quite a bit of play in the shaft. It may also be because I was using some $4 bits I bought off of ebay.
I was thinking about buying a special drill press for PCBs, but before I did I though I would ask you guys what you use.
Thanks a ton for your time!!!
Dan
Of course you're right, Chris. Sometimes I should just hold my tongue.Uhhh, I was going to post my two cents but when I see friends snapping at each other I think it best that I pass on this one.
I see nuuuthing! I hear nuuuth-ing! I Know nuuuu-thing!
Chris
Now that's scary!Blimey. I sounded a little like Colin there...
Of course you're right, Chris. Sometimes I should just hold my tongue.![]()
I promise not to snap.Now that's scary!
It's just that I've always felt very comfortable here at EP. Kinda like a big happy family. But then again families, even though they love each other, do fight now and then.
So, that said. IMHO, drilling fiberglass PCBs should be done at high rpm at ~10,000 RPM with Solid Carbide bits and ABSOLUTELY NO Freehand Drilling.... EVER! This should be SOP! If the bit it held in a Jacob's type chuck then it's best that it's shanked. Even collets at these diameters are struggling to hold the bit securely. So shanked carbides are a good choice.
Cheers,
Chris
Ha! Mr.Ed. I love seeing him again on OTATV! He's smarter than Wilbur.I promise not to snap.
I think that it's 'horses for courses' Chris, <snip> When doing my woodwork, I regularly use 1/4" router bits in mine, at 20-25000 rpm.
Sex??? What's that.Ha! Mr.Ed. I love seeing him again on OTATV! He's smarter than Wilbur.
I've also noticed that there are very, very few electronics heads that are not also amateur machinists and woodworkers. Check it out. You'll see that I'm spot on! I think it translates to .. Electronics Heads are arguably the most creative, resourceful and broadly skilled demographic on this Earth,... and somewhere in between all their activities, they still manage to fit sex in there tight schedule to create what will hopefully be perfect harmonics!
Cheers,
Chris
We'll have to talk woodturning in our own thread sometime. Yes, I love it more than any other woodworking discipline.Sex??? What's that.
Yep, I've been surprised how many of us are also into woodworking. (chopnhack for one - the name gives him away.)
For me, mostly woodturning,
