John Steaver
- Oct 28, 2015
- 35
- Joined
- Oct 28, 2015
- Messages
- 35
Hi, with a van de graaff generator, does the voltage increase with a higher RPM motor or a different material?
It depends on where your losses are occurring, and whether you have a "serious" Van de Graaf generator or just a "toy" good mainly for making hair stand on end.Hi, with a van de graaff generator, does the voltage increase with a higher RPM motor or a different material?
Yeah, it's really hard to hold off corona discharges in air. Making the sphere larger helps "smooth out" the electrical field. The larger columns are needed to support the weight of the moving belt or chain. When these things were first invented, they sometimes built two of them with opposite charges on the spheres to effectively double the voltage capability.Thanks for all your help. Now I understand why the sphere and columns are so big when the voltage is higher.
thanks again- John
Google is your friend here. The answer is:just one more question, what is the capacitance of the sphere? ...
Define "normal capacitors" please. The continuous discharge from a Van de Graaf occurs because a continuous charge is being delivered to its "spherical capacitor" by the moving belt (or chain in the case of a Pelletron).Why cant normal capacitors discharge a continuous flow of energy?
You never "deliver" voltage to a capacitor, spherical or otherwise. Voltage is the result of charge being moved from one plate to the other plate of a capacitor: V = Q/C, where V is the voltage in volts, Q is the charge in coulombs, and C is the capacitance in farads. In the case of the spherical capacitor on a Van de Graaf generator, the Earth is one plate and the sphere is the other.wait, what if voltage was delivered to the spherical capacitor without any belts, combs etc
