- Joined
- Dec 18, 2013
- Messages
- 5,178
And if dual rail needed a switched capacitor converter will do eg:
http://www.analog.com/en/products/p...itor-converters/adm8829.html#product-overview
Good call. I have used these before for just this purpose.
Adam
Good comments from GPG. I assumed that since the sensor output -0.5 to 0.5V it was already amplified by an op amp, but apparently not. So a buffer amplifier is required before the summing (or differencing) amp.
One more thing, though:
Even a rail-to-rail amp will not allow the input to go all the way to zero with a single supply. So you should either use dual supplies, or map the range to something not including 0, such as 1-5V if you prefer to use a single supply.
Bob
From LT1635 dataEven a rail-to-rail amp will not allow the input to go all the way to zero with a single supply.
Whoops, I meant output, not input. For the popular LM324 single supply opamp it can only go to about 40mV.From LT1635 data
"The input common mode range of the op amp includes
ground"
LOL I thought you did.Whoops, I meant output, not input. For the popular LM324 single supply opamp it can only go to about 40mV.
Bob
