Sensor interface, OP AMP, -500mV +500 mV to 0-5 V amplifier
Arouse1973
Adam
Dec 18, 2013
5,178
Good comments from GPG. I assumed that since the sensor output -0.5 to 0.5V it was already amplified by an op amp, but apparently not. So a buffer amplifier is required before the summing (or differencing) amp.
One more thing, though:
Even a rail-to-rail amp will not allow the input to go all the way to zero with a single supply. So you should either use dual supplies, or map the range to something not including 0, such as 1-5V if you prefer to use a single supply.
Yes Bob, that's why I used -1 Volts, but it could be -5V. So a combination of my circuit and yours should fit the bill.
Adam
GPG
Sep 18, 2015
452
From LT1635 data
"The input common mode range of the op amp includes
ground"
From LT1635 data
ground"
Whoops, I meant output, not input. For the popular LM324 single supply opamp it can only go to about 40mV.
GPG
Sep 18, 2015
452
Also the output will go to within 15mV of the rails into a high resistance load.
The only thing missing is whether a few nA input current is ok or should pA be required. OP?
