brasilmom . . . . . . . . . . .
So now we know what your specific unit looks like and how it performs:
or / and
( I wonder if the vapors will put profuse fine hair growth on your forearm, as in the the first videos still picture ? )
I have now viewed the circuit board electronics on your unit and see no high voltage related step up, and research shows some units working from as low as 5V ultrasonic drive level.
So, as suspicioned, you just seem to have a bad transducer.
The Young Living Distributors seem to have NO technical parts supply, they just SELL new units or SWAP out in warranty units .
The only transducer source seems to be the original manufacturing source in China, where they are catering to you with replacement transducers.
BUT you are going to need minimal technical help in the respect of getting the assistance of some LOCAL person that is technically astute enough to perform this test :
(WITHOUT the transducer being plugged in) Use his /her triggered oscilloscope and loosely couple its probe to the lead of the transducer plug, which produces the greatest signal output.
Measure the time period between one cycle of the ultrasonic signal and pass on that information to interpret the operational frequency of your unit.
BECAUSE one needs to match the new transducer to the same frequency that the Young Living ultrasonic drive signal is operating on.
Of the transducers being offered, I see, some are operating at 40 KHZ, some at 60 KHZ and some even go up into the low RF range of 1.7 MHZ.
Using these supply sources, and weeding out the ones that require 15/30 100 units minimum purchase quantity, is the only CHEAP repair sourcing.
Plus they seem to suggest that the norm lifespan of a transducer is in the 5000 hour usage time frame. So some spares might be in order.
FIO . . . . . Letting one run DRY, with out the wet loading, will impair its lifespan.
Transducer supply sources :
http://www.dhgate.com/product/high-...-maker-25-mm/255608012.html#s1-2-1b|655240122
http://www.dhgate.com/wholesale/ultrasonic+humidifier+transducer.html
http://www.aliexpress.com/popular/ultrasonic-humidifier-transducer.html
73's de Edd
( Now, do duly note, that "spel chek" just TOTALLY gave up, on all of the forthcoming )
Oh, agora para o seu Português:
or / and
(Eu me pergunto se os vapores vai colocar profusa crescimento do cabelo fino em seu antebraço, como nos primeiros vídeos imagem estática?)
Agora eu já viram os placa de circuito elecronics na sua unidade e não vejo alta tensão de passo relacionado para cima, ea pesquisa mostra algumas unidades de trabalho de tão baixo quanto 5V nível de unidade ultra-sônica.
Assim, como suspicioned, você só parecem ter um mau transdutor.
Os jovens que vivem Distribuidores parecem não ter fornecimento de peças técnicas, eles apenas vender novas unidades ou trocar em unidades de garantia.
A única fonte ransducer parece ser a fonte original de fabricação na China, onde são buffet com transdutores de substituição.
MAS você vai precisar de ajuda técnica mínima no que diz respeito recebendo o assistane de alguma pessoa local que é tecnicamente astuto o suficiente para realizar este teste:
(Sem transdutor a ser conectado) Use seu / sua oscillicosope acionado e vagamente casal sua sonda para a liderança da ficha do transdutor, que produz a maior saída de sinal.
Medir o período de tempo entre um ciclo do sinal ultra-sônico e transmitir essa informação para interpretar a freqüência operacional de sua unidade.
PORQUE é necessário para corresponder ao novo transdutor para a mesma frequência que o sinal ultra-sônico Jovens Vivendo unidade está a funcionar com.
Dos transdutores que estão sendo oferecidos, eu vejo, alguns estão operando a 40 KHZ, alguns a 60 KHZ e alguns até mesmo ir para cima na gama baixa de RF de 1,7 MHZ.
Usando estas fontes de abastecimento, e eliminando os que exigem 15/30 100 unidades de quantidade mínima de compra, é o único abastecimento de reparo barato.
Além disso, eles parecem sugerir que o tempo de vida normal de um transdutor está no uso de calendário de 5000 horas. Por isso, algumas peças pode estar em ordem.
FIO. . . . . Deixando um funcionamento seco, com a carga molhada, irá prejudicar a sua vida útil.
Fontes de abastecimento de transdutor:
de Edd
E. . . .a primeira comunicação
Eu também acredito que o seu "problema" é que as unidades de transdutor, e ao nível de potência que você está exigindo para a sua aplicação, seria a utilização de uma unidade de ativador da família de Pb titanato de bário.
Além disso, esse nível de energia estará exigindo-se sobre para a região quilovolts (s) de nível de condução estática.
A sua unidade tem desenvolvido "perfurar" / arco e gerador + fornecimento de energia ultra-sônica está respondendo ao carregar para baixo.
Ele não pode lidar com o aumento atual. . . . . ma de, em vez de microamps. . . . . que esses arcos são exigentes.
Eu não consigo ver um ohmímetro revelar isso em tudo menos que haja uma chance remota de um leve rastro de carbono tendo desenvolvido. . . . Acho que não.
Esta unidade tem um irmão mais velho no conceito de design na forma de um agregado familiar ou hospitais vaporizador ultra-sônica.
E outro irmão BIG seria na forma de um poder limpador ultra-sônico.
Outro irmão BIG seria um detector de tensão / falha para os metais.
MAS, o seu poder de unidades de transdutor de excitação cai dentro dessa categoria "doméstico ou hospitais de ultra-som vaporizador".
Então, olhar para obter um transdutor de energia de substituição do fabricante de unidades ou uma unidade a partir de um agregado familiar ou hospitais vaporizador ultra-sônica.
Também parece que sua unidade tem uma falha de electro-mecânica, no que respeita à parte do metal emissor SS sendo afastou e deformado e não sendo ligado ao PBT por cerca de 1/4 da distância do fio AMARELO.
Isso destrói estragos GRAVE por não ter a parte que está sendo acoplado mecanicamente e, principalmente, o deslocamento da ressonância do transdutor de correspondência para a frequência de alimentação de entrada.
Eficiência eficaz pode cair todo o caminho até a 10%.
Se você enviar mais fotos das principais unidades coragem ea unidades de marca e modelo número, info mais exigente para uma substituição transdutor pode ser alcançado por nós.
Dar também a tensão da linha e potência, como ler a partir do rótulo da unidade.
tchau . . . . . .
