Let's do an omh continuity test.
0 ohms, if there is continuity .
Do the test in DMM ohm range(buzzer if there is one ).
Between same color points (one on IC controller,
Green is a "good realy channel" ,pin #9
REd is the "Bad relay channel", pin #10
Do it like the pic shows(on the componnents legs).
cable connected between the 2 boards.
No power!
what do you get?
View attachment 24063 the athor on resistor):
Nothing. No beep. No continuity. Hope that's good news. I need to hear some already.
Jonathan
Edit: I misread. and did that wrong in the first try. Green Green is probe black and white then Red red is probe red and white too. That's what you meant. Yes there is continuity between those two points.
