1: 31.78KΩ 2: 94KΩ 3: 3.1MΩ 4: open![]()
2:12.4MΩ
3: 12.4
4: 11.10
5: 11.7
6: 12.6
I am not 100% sure what you mean with Board GND to pins 12/13 or with 5V connected to pins 11,32 but I will make a guess and post the results. I will probably be available same time tomorrow. 3:00--6:00 PM for me.
GND to 31 is 0.4Ω
GND to 12 is 0.4Ω
11 to 5V .3Ω
32 is same
I wouldn't try to change the Socket (all of it or some pins ) yet,
just clean it the best you can.
The main issue is deciding if the IC is Bad or good.
I do think it is Bad, but not yet 100% sure.
You say it is partly working - display is changing when you press something,was this this correct?
If it is Bad ,getting another IC and replacing it isn't very simple (probably not cheap either).
Contact the manufacture and enquire about the IC availability and price,that is of a "burned"/programmed IC (there may be a possibility to get the file to be burned in an "empty" IC).
For that they should be able to identify the model and board exactly...
For now I would do the following:
1. Clean the IC and socket the best you can.
2. Carefully insert the IC back into the socket, and watch out for the correct
pin #1 marking!
3. Connect the boards together and power-up.
4. On the IC Check DCV between pins 11 and 12 ,and between 32 and 31
(do that directly on the IC pins,not at the board)
5. Watch to see if you can change the display
-that is an indication that the IC is working ,at least partially.
6. Measure the voltages directly on the IC pins (again not at the board)
relative to GND.
Pins 5 to 10( a total of 6 pins) while trying "to make the relays click" using
the remote or what ever button there is on the chair for that thing
(i.e. Back and Leg).
noteins 5 and 6 are also part of Back/Leg activation .
Let us know what are the results you find.
Ok, I'm back. The chair is completely operated by the remote. The remote is plugged in right beside the main IC on CN31. VCC RX TX GND.
I found one of those tools to put in the IC properly so here I go
Pins 11,12 is 5.0V
same voltage for 31,32
pin #1 marking!
relative to GND.
note pins 5 and 6 are also part of Back/Leg activation .
Ok. To continue this list of measurements
5. The display changes with the press of the buttons. I will try to take a video of the display in action and what it does.
Pins 9-5 display no change when I activate Back/Leg.
Pin 6 has 5.5 VDC Back/Leg activated or not No cange
Pin 5 has 1 V
What about
1.Are there any buttons on the remote that function properly(activate something on the unit)?
2.Please check voltages on CN31 (relative to it's GND, remote plug out)-3 measurements. Vcc is 5V ... all the pins are 5v relative to ground.
3.Please connect the remote plug and check voltages on CN31 All three pins have 5v relative to ground even with remote plugged in.
pins 2 and 3 without pressing and with pressing a button on the remote-like Back/Leg etc.
what do we get?
Ok after bringing the board to the chair and plugging in the solenoids, vibrators and air pump. I know now that I definitely can affect the board with the remote. The air bag massage turns on automatically as soon as the chair is booted up and finished chirping. I think the chirping might be the chair trying to bring the back and legs to neutral position.
I can change the mode of the airbags. I can change what type of massage they give and they will respond accordingly. I can also use the remote to turn off the air bag massage.
At the same time. I also believe that the airbag massage is almost completely controlled by a separate IC on the board. I will circle the area in a picture here. View attachment 24122
The remote is connected only to the controller IC (pins 2,3 of CN31).
We don't know what "HW/SW protocol" is implemented between them.
But everything on the board is control by the controller (with "help" from other devices).
Try this:
1.Remove the Controller IC from the socket(without power).
2.power up(with remote ) and try activating the air bags-you will have no control!
watch if the remote functions with it's beeps etc.
3.In this instance(IC out of socket) we can check the un-clicking relays properly:
Use a solid wire(or a low resistance resistor say up to 100 ohm).
and under power connect one side to 5v (pin11),with the other one at a time, touch each of the IC pins 7,8,9,10 on the IC sockets (count well !)
This should cause the relays to click one at a time.
I'll be out for the next 4 hours,
Good luck and Happy new year
View attachment 24125[/QUOT
I was able to make relay 2,3,4 click by jumping pin 11 to their respective pins. Not 1.
When I powered up the board without the control IC. The remote completely lit up. All the icons were on and the backlight. But I don't think it was really on. The buttons did nothing and no icons ever went off.
