Hi Jonatan,
There seems to be a problem with the " forum alerts",I didn't see any.so I checked the thread directly.
To our board...
1. There is another pair of resistors with suspicious values,near the MOCs.
The Photo is not completely clear(see below),
what I see is 120K [brown (violet?),red,yellow],that is way too high!
What is the actual value ?
2. The purpose of checking the voltage on the 1K (10k) resistors was to determine the value of the BTA12(8) gate-current.
Calculating by dividing the voltage(AC) reading by the resistor value.
That is how we found out that the resistor values are too high.
3. from #240
"When I short Pin 4--6 on the MOC I get 120V at the diodes. But turning the LED on on the other side does not have that effect"
Not completely clear:
Which diode is 120V and which isn't ?
By "LED" you mean the MOC's?
4. Did you mange to clean the socket well?
no corrosion in the inner contacts?
5. I don't understand the bottom right red arrow on your last Post.
To our board...
3. from #240
