What are these basic components?
Status
Not open for further replies.
juntjoo
Jun 8, 2015
142
Never mind what I'm doing here: I'm not even sure, but I would like to at least know what I'm looking at and you'll notice these two bulbs along both separate cables. The first one is at the end of a laptop power adapter. It already has it's transformer at the wall connection like most standard power adapters. The second one is attached to an external laptop batter charger, which also has it's own separate transformer, which I lost, hence this Frankenstein project.
So... I've ended up with two of these weird bulb'ish components which I'm wondering is the cause of my slow -as-molasses charging.
Anyone know what these are? Thanks.
Harald Kapp
14,308
The "bulb" at the left is a ferrite to block HF common mode ínterference. You see this type commonly on charger cables, laptop power supplies, monitor power cables etc. This ferrite is definitely not the source of slow charging.
The box at the right I cannot identify. Show us a close-up from all sides.
Slow charging is commonly caused by one of two causes:
  • The power source has not enough power (output current)
  • The device to be charged requires some kind of identification (often a defined resistance) to allow drawing a higher charging current than usually possible. This latter method is often used in combination with USB charger ports.Without proper identification the device to be charged will draw only the max. specified current and take longer to charge.
Regards,
Harald
juntjoo
Jun 8, 2015
142
Regards,
Harald
Thanks Harold. http://www.amazon.com/External-batt...ry/dp/B00FIJZAU8#immersive-view_1454189197895
Hope that helps. Both charging cables are designed to charge the same battery, but one is directly, the other through the computer. So if I had the original transformer for the external charger that would work perfect, otherwise obviously charging the battery through the computer with just the laptop power adapter also would charge perfectly, which it does but I'm trying to have a two charged batteries setup for long distance computing. Planning on getting a third battery if I can't get these batteries to charge externally faster than 11 hrs lol.
juntjoo
Jun 8, 2015
142
There is no other indicators on that component to make use of a closer-up view of it unfortunately.
juntjoo
Jun 8, 2015
142
If we can assume the original laptop power adapter has the correct settings should I just splice it directly to battery right at the external cable's connector pins before that bulb? Or does not the laptop power adapter connect to the battery directly through the laptop but go through other important circuitry?
Harald Kapp
14,308
Since I don't know what's inside the black box spliced into the cable near the battery pack, I cannot give clear advice, I'm sorry.
juntjoo
Jun 8, 2015
142
Well thanks anyway. I'll report back if I decide to open it up. Can ya narrow it down to a couple possibilities?
Harald Kapp
14,308
I recommend you use the cables as intended. Lithium batteries are dangerous stuff when treated improperly.
juntjoo
Jun 8, 2015
142
Harold! It says "MPU" in it. Missed that earlier. What does that mean? I want to cut it out to hopefully free up some current/voltage to get this to charge faster. Unless you think that means something important like micro processing unit ... Could it? I've read laptop battery charging and the batteries themselves are complicated. That the batteries have computers in them themselves. What do you think?
davenn
14,484
This is not likely to happen
you have already been told that the one on the left is a ferrite choke for noise suppression
removing it isn't going to affect V or A supply
The one on the right looks like some adaption for the cable between 2 different connectors
there may also be a ferrite choke in there ...
removing that section is again unlikely to have any effect
The charging rate for the battery is set by components internal to the laptop
There wont be anything you can do about it
Dave
juntjoo
Jun 8, 2015
142
Dave
Yeah, the "other one", not this one, hence my persistence. Don't suppose you have any idea what MPU stands for do y'a?
davenn
14,484
what "other one" ? what "not this one" ?
You are making this so difficult !
MPU - who knows ? ... it could be as you suggested or it may be a manufacturer's name
juntjoo
Jun 8, 2015
142
You reprimanded me for not paying attention when I was already told about the one on the left, which I pointed out want the one on the right, which is... Never mind. Anyway. You've left me no choice but to put it under the knife. TBC...
davenn
14,484
OK we will close this thread
you can start another one at some later date if you have success to report :)
Status
