How to check if LCD module is not dead with basic components like switches.
Hi there,
I found an old LCD module. I'm not sure if its working. Is
there a simple method to check if the module is working (without
connecting it to ,uc) , like using switches.
Thanks in advance
BO
Arfa Daily
Hi there,
Thanks in advance
BO
In general, no easy way. May have on-board test mode, but you need to know
how to get into it.
Arfa
Lynn Coffelt
Hi there,
Thanks in advance
Well, I don't know exactly what your module is, exactly, but some of
the older, 7 segment digital LCD's maybe with the addition of a dash, comma
or decimal point could be checked with an old analog VOM. Put the VOM on one
of the higher resistance ranges, and use the test leads as a voltage source
to activate one segment at a time. One lead to the "back plane" and the
other lead to the segment being checked. (can't remember now which polarity
worked best..... won't hurt if you get it backwards first)
If you hold the module to the light just right, you may be able to see
which pin, land, or oxide plated area is connected to the segment you want
to test. The "illumination" or polarization (?) won't be at full contrast,
at all, and you may have to hold it at just the right angle to see it work,
but work it does! And if there is any contrast change at all with applied
voltage (with the correct polarity), there is a 99.99+% chance that segment
is OK.
Now, if it is a dot matrix LCD, this method may be not practical.
Additionally, if it is a module with built-in driving transistors, this
method will not work at all.
Old Chief Lynn
DaveM
Hi there,
Thanks in advance
BO
There are a number of web sites that are dedicated to LCD modules and their
uses. In general, your LCD module must go through a predetermined power
on/reset initialization sequence before it can be brought to life. The
initialization sequence has timing requirements that you will probably not
be able to accomplish with manually actuated switches.
Your best bet in this case would be to use the printer port on your computer
to test the module. There are loads of software examples on the web that
demonstrate this functionality
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in
the address)
Never take a laxative and a sleeping pill at the same time!!
