Hi All,
I was wondering if somebodycan give me some help in understanding this circuit. The first stage is a inverting amplifier stagevwith gain of -1. If I put in 0.5V I then get -0.5V.
This goes into a second stage which the N channel FET is in the feedback loop of the opamp, It is a negative constant current. The opamp adjusts the gate drive to keep its inputs the same, the output is then Vin / 10K resistor.
My question is that the FET drain is at 0V, the source will be at negative potential. Is this why this circuit works?
I always thought the Drain should be more positive than Source also the gate needs to be higher than Source. So can this work as Drain is higher I.e. 0V than the negative source ? As long as the gate is greater than threshold of FET. Does this work in the triode or linear region if the opamp? Like a potentiometer?
I look forward to hearing from you.
Best regards,
Rajinder
Best regards,
Rajinder
