73's de Edd
- Aug 21, 2015
- 3,730
- Joined
- Aug 21, 2015
- Messages
- 3,730
Sir Constantine . . . . . . .
Yes headphones work fine.
That makes me feel even more that the power amplifier section is not working correctly.
The headphones get their drive from the SAME speaker drive line.
With only a variance of inserting some series resistors in their feed line line for attenuation.
Also if you are hearing audio through the headphones, that means that the protective Rly901
has NOT tried to disengage the speakers and headphones, due to a fault.
JVC Manual page 10 or ADOBE page 7 explains the units specific speaker switching action.
Well in looking at the power supply scopings, I see no abnormalities, ripple wise .
HOWEVER you do have one bodacious level of 52khz signal, present at the shared Q770 and Q772 emitters, as the power output for that channel.
You are certainly not going to be hearing that POST- ultrasonic and -SUB RF frequency !
Flip the input off the present CD position in an attempt to see where ? that high frequency signal is coming from ?, while you are scoping that channels output.
You might go back to the audio source input that was previously letting you hear a feeble audio through the speakers.
73's de Edd
73's de Edd
