ok correct me if im wrong in this idea
what will make the primary winding be overheating is more voltage than what it's design to work on
not quite right
2 main things that will cause the transformer to overheat and the thermal fuse to operate
1) excessive current draw on the secondary side, which will increase the current on the primary side as the transformer tries to supply the extra current
2) large voltage spike / surge on the primary side
we have no easy way of telling which of those 2 may have caused the failure, tho if there is a lack of other failed devices around the house
then #1 would be the most likely reason
again ... a correctly rated thermal fuse is your ONLY safe option
Dave
