48v DC - what switch do I need?
Dan Easton
Jun 14, 2016
8
I have a golf buggy powered by 8 x 6v batteries.
I want to power some 12v accessories (which pull no more than 5 amps), so I've got a 48v to 12v step-down which I'm going to wire-in to the batteries. However, I also want an inline switch to be able to disconnect the voltage regulator when no 12v accessories are being used.
What switch can I use? There are a lot of 12v/16amp ones available. As the ampage of my accessories is so low, can I use a 12v switch??
Gryd3
Jun 25, 2014
4,098
No.. Voltage must always be matched or Exceeded for 'components'.
The 'Current' must also be matched or Exceeded.
You never want to undersize the voltage or current rating.
Minder
Apr 24, 2015
3,561
12v switch no problem
As long as it is on the output side of the voltage regulator, if on the input then you need a 240vac rated one
M.
Dan Easton
Jun 14, 2016
8
Wow - quick replies. Thank you.
It'll be on the 48v side of the voltage regulator
Ok, this makes sense. I just wasn't sure if getting a 250v/16amp switch would be overkill and cause problems.
Thanks for the advice.
Minder
Apr 24, 2015
3,561
If the unit is not in use for some period of time i would tend to switch the input side of the regulator.
M.
BlackMelon
Aug 7, 2012
189
I think it is crucial to have a switch rated at higher than 12V. Inductor kickbacks tend to cause overvoltage problems on the switch. Putting a diode across a correct component should alleviate this problem, so by doing this, you might be able to use a switch rated at 12V.
BlackMelon
Minder
Apr 24, 2015
3,561
The main reason for voltage rating is insulation value, surprisingly automotive relays are made with high voltage insulation, as is most components now. It is not worth making items with low voltage value insulation.
The voltage difference between 12v and 48v is minor, AFA insulation is concerned.
M.
Kiwi
Jan 28, 2013
505
Make sure you fit a fuse in the positive wire to the 48v-12v reducer. The fuse should be as close to the positive take off point as possible.
davenn
14,473
BlackMelon
this isn't relevant in this case ;)
Dave
Dan Easton
Jun 14, 2016
8
sp
Just realised I don't actually know what sort of fuse to put in. Can you get 48v fuses? What amp rating?
davenn
14,473
sp
not that I'm aware of, typically a 240V rated one is used and rated at just a little more than you max current likely to be drawn
with the note ... as long as none of those accessories have huge start up currents ... eg motors
