Hi Y'all:
I am trying to use the 555 in a monostable mode. I trigger the timer on and output stays high for duration of 1.1RC =T. All is fine. Pin 3 (output) goes low when Pins 6 reaches 4.6 V (2/3 Vcc =6.6v) and 7 (discharge) for some reason does not discharge the timing Capacitor at that instant and pins 6 and 7, which are connected together, remain at or a little lower than the 4.6V level. I then short the trigger to ground again and the output goes high again but since the timing capacitor is near threshold voltage, the output pulse width is very short. The only way I can get it to time out properly is to disconnect the circuit from Vcc and let the RC circuit bleed down on its own for a few minutes and then I can reconnect Vcc and get it to work and give me one and only one proper output pulse width. I jiggle the chip in the socket, in case of a bad connection but it doesn't help.
