Heck yeah. They're a MUCH better choice for projects that demand juice. I only suggested stacking buttons because I thought you were committed to them., or i can use 3AA batteries, as suggested!
I can't modify the thermal switch module, it works fine : D i just need to connect it up to things using the 3 pins on it
No, it actually pulls low.The DO output a positive current, I believe
Do you understand what the terms "Source & Sink" mean? Steve eluded to it but you may not have grasped to concept.The DO output a positive current, I believe
See post #36: LED OFF, RELAY ON. See my post #38. The opto-isolator in the SSR has a 440 Ω current-limiting resistor and the SSR needs about 4 V to light-up the opto-isolator LED and turn the SSR ON. So, the OP needs to place SSR control between the collector of an NPN transistor and Vcc, drive the base of the NPN through about 2 kΩ connected from Vcc to DO, connecting the base to DO with the NPN emitter connected to common.
It does output a positive current from Vcc through the on-board 10 kΩ "pull-up" resistor when the open-collector LM393 comparator goes "high" and thereby removes the path to common for the LED, turning the LED OFF. I am assuming you want the relay to actuate when that happens.The DO output a positive current, I believe
Perhaps, (to be more precise) I should have said the LM393's "Output Pin is Open Collector Logic" thus can not source. As Hop stated DO is sourced through the 10KΩ pullup resistor.Do you understand what the terms "Source & Sink" mean? Steve eluded to it but you may not have grasped to concept.
Chris
Edit: So there should be no misinterpretation here, your comparator (DO) is Open Collector logic. This means it can NOT source current. It can only sink it.
This is true. But see this: "it (the LED) seems to go off when the temperature goes above setting, which is when i would like the relay to activate" which was re-iterated in post #35 and confirmed by Steve in post #36: LED OFF, RELAY ON.... Regarding DO's output logic.... I thought we settled this as LED ON thus DO= low! ..
You don't need to know much to get your circuit working. The SSR will work "better" than a relay.all efforts to educate are appreciated, even if i don't get half of it, mostly about resistors
i'll let you know how successful i am when the SSR reaches me
With the SSR in the transistor collector circuit, there should be no problem lighting up an LED that might be present on the SSR. Nice feature, that.the SSR may have a visual indication it is on (via its own LED), which is another advantage.
Yes, the transistor is necessary to provide both operating voltage and current to the low-impedance (440 Ω) control input terminals of the SSR. The existing 10 kΩ internal "pull-up" resistor connected between Vcc and DO will act as a voltage divider to the 440 Ω input impedance of the SSR, dropping the voltage applied to the control terminals of the SSR below what is necessary to reliably turn the SSR on and limiting the current that can be supplied to the SSR's internal LED/optical isolator.No, you need a transistor just like in your first post.
