Any ideas - Rotary momentary switch?
rockrockmcrock
Dec 19, 2011
41
So I'm converting a non functioning 12v old 60s radio to mp3 and Bluetooth. The challenge I have set myself is to maintain the exterior completely and hide all the modern controls by using as many of the existing knobs as possible.
To save time I've bought an OTS mp3 board and decided to only build the amp myself. The modern mp3 board uses push button momentary switches for FF & RWD. The old radio has 2 rotary knobs - I'd like to make use of one for FF and RWD. I could do this if I could find a 2 way momentary rotary switch off the right size.
All the rotary momentary switches I've found so far are 240/110v massive types that are too large for the application which needs a standard 15-20mm with 6mm shaft 12v type. Any ideas where I can find one? Or is there a better way to do this?
Chris guys - all thoughts welcome!
Alec_t
Jul 7, 2015
3,817
I'd bet not momentary. If it were me I'd probably find a way to attach a spring to bias it to the centre position :D.
duke37
Jan 9, 2011
5,364
One way, perhaps a bit inconvenient, is to place some reed relays inside the cabinet and use a hand held magnet to activate them.
Are you going to get the old radio working, at least for the sound output?
rockrockmcrock
Dec 19, 2011
41
That was the plan so If I can I'm going to reuse the amp circuit, but having opened it up I'm not hopeful as it's quite clearly been subjected to some water (or coffee/tea) damage inside from the top. Outside was fine though - go figure!
On the momentary switch one possible work around I was thinking of was a couple of lever arm momentary buttons and a spring clip - but that's not ideal! I can't believe there isn't a momentary rotary out there that isn't a 240v breaker - it's mad!
Bluejets
Oct 5, 2014
7,374
If you have the room internally , one could arrange the rotary switch to operate mini relays on a momentry basis.
Use the clean contacts in you main circuit.
How about a rotary encoder?
rockrockmcrock
Dec 19, 2011
41
@Blue - not a bad idea thanks, but I'd lose the long press action. Still if nothing else works that might be the only way forward
@Steve - it did cross my mind but had 2 issues: 1 finding an encoder with a long shaft and at the right size (usually they're small pcb mount types); 2 I'd have to start messing with coding, not an issue skills-wise but I blew my Pic2 kit earlier this year so I really wanted this project to be simple and cheap.
Externet
Aug 24, 2009
943
rockrockmcrock
Dec 19, 2011
41
@alec - like that! Not for this project as the knobs are inset, but for others that's a classic piece of kit - a sort of micro joystick!
@Externet - now that's lateral thinking - the Amazon link is too big bit I have smaller ones in my Ford that would fit. However the 3 pole and lever arm is a great alternative. I'm thinking a 3 pole sprung toggle (or even 2 momentary spring toggles) may work well and provide the spring bias around centre. Ok I'd have to make it but as ideas go that's the best so far if I can't find an OTS rotary.
rockrockmcrock
Dec 19, 2011
41
Darn - just checked the knobs in my motor and they're not sprung :-( so so far the spring momentary SPDT toggle and a pushrod is looking the best option
Externet
Aug 24, 2009
943
If you put a lobe on the original shaft, and 2 of these...
----> http://www.cadsample.com/wp-content...sition-Microswitch-3D-Solidworks-Drawings.jpg
Action set for partial lobe rise will produce return-to-center when released.
There is also this kind of switches that an eccentric lobe on the shaft can do the desired action
Or, a magnet on the shaft and two reed switches... Explore joystick mechanisms too.
Your switch does exist out there. Just matter of coinciding your search with the correct terminology for it.
