Hi,
I was lead here by google and found this thread. Unfortunately the TS abandoned the project because the main IC was apparently damaged.
I am having an issue with this board as well. I've so far repaired the damage that was present on the board, however putting it back into the machine causes R020 to disintegrate instantly, so something must be shorted in the board itself.
Initially I replaced L003 (470µh choke) and R020 (22 Ohm 3w), i also had to repair a trace that was burned out between C021 and, i'm assuming TP147... it's hard to tell because the trace is hard to follow and i'm having a hard time discerning on the schematic what the trace is feeding into other than C021.
I've since also replaced the main filter caps C023 and C022, the diodes D029 and D030, D006, the MOV RV07 and the LNK304PN, as I had those components left over from a kit I bought and I figured it couldn't hurt replacing them.
Attached pictures show the repaired area, and a picture of the R020. I apologize for the crappy soldering job, my soldering station went up in smoke and i'm making do with what i could find in the only hardware shop I could find that was open on sunday. I had NO IDEA what a challenge it is trying to desolder components with crappy generic soldering iron.
Some extra information: the LNK304PN was NOT damaged in my case, but i replaced it anyway, since i had it in a kit. The only damaged components were the R020 and the L003, and the burnt trace. Everytime i plug it in the R020 goes up in smoke and the repaired trace gets hammered and charcoaled... I've been poking my probes at this thing all day trying to find a short, and I'm out of ideas.
