How to find a replacement for a transformer of whirlpool oven control board (8303505)
Status
Not open for further replies.
Robert24
Jul 26, 2024
4
The oven went blank after self cleaning. I found two damages: 1) the thermal fuse is broken; 2) The transformer in the control board is broken. I need the help to figure out the specs of transformer and where I can find a replacement part. BTW, the control board is obsolete and no longer available.
The transformer pin out: 1) four pins in primary, I guess it is double 110V. 2) 5 pins at secondary. The transformer is made by ELYTONE. There are some model number shown in the picture. However, I don't understand how to read it.
I read some thread about the possible fuse build-in under the transformer. I highly doubt it since there is no conductivity between any of four pin at the primary side.
Thanks for help.
Robert24
Jul 26, 2024
4
I added one more picture and the wire diagram
Robert24
Jul 26, 2024
4
Anyone knows where to find the schematic or BOM? or how to understand the specs of transformer from its label.
Delta Prime
Jul 29, 2020
2,996
Whirlpool manufactures products under various brands. Lucky for you a replacement for a transformer for whirlpool oven control board (8303505) using the transformers name plate details
Canbe found in these brands. Because you're transformer is used in one or more models of these major brands.
including Whirlpool, Amana, KitchenAid, Maytag, Jenn-Air, Magic Chef, Roper, and Admiral. Additionally, Whirlpool produces items for Sears-Kenmore and Ikea. is also compatible with gas ranges from Maytag, KitchenAid, Jenn-Air, Amana, Magic Chef, Admiral, Norge, Roper, and some Kenmore models. a little research is necessary in the before mentioned site.
Well, if you know anything at all, that would be expected if any fuse were buried in there and it blew.
Show a closer detailed version of your photos so anyone can make out any markings on the pcb around the transformer and all the relays especially.
Some detail may be assumed from there.
Then include a drawing of the pin spacings on the transformer and detailed photo of the opposite side of the pcb.
In future, before or when you submit drawings, photos etc. take a look and see what we have to see.
If not clear and precise, update the photo/drawing so it is.
Robert24
Jul 26, 2024
4
@Bluejets, please see the picture above (board.jpg). If you click it, you can zoom in to see the pins of transformer. I had the mark on the picture.
Up to you....supply required info or work it out yourself.
ethancr
Sep 8, 2026
5
I’d start by identifying the exact voltage and current requirements of the original transformer rather than relying only on the part number. The secondary voltages are especially important because the control board may use different rails for the logic and other circuits. If the original transformer is completely open on the primary, it would also be worth checking whether there’s a hidden thermal fuse or another protection device before assuming the winding itself has failed. If you can get clear photos of the transformer markings and measure the secondary voltages, that should make finding a suitable replacement much easier.
Status
