HellasTechn
- Apr 14, 2013
- 1,579
- Joined
- Apr 14, 2013
- Messages
- 1,579
Hello friends.
I have this question for you.
I am building microcontroller project with a Picaxe and i want to be able to reprogram it without rmoving it from the PCB. so i was thinking that ok Serin pin uses the 10K resistor as pulldown when nothing is being downloaded to it but what about Serout pin that connects to the RXD pin of the PC through an 180 Ohm resistor ? when main program is executed will Serout pin not float ?
The rest of the picaxe pins will be either used or connected to ground through 10K resistors.
here is the diagram of the download cable circuit according to picaxe manual.
Thanks !
Thanks !
