Lights up the Recording Meter DisplayWhat does the bulb do? I mean, what does it light? Meters or switches...?
E10 is the name of the connection, Phillips is the manufacturer.
If you can find the voltage and wattage, go look for an E10 bulb with those ratings.
Assuming the bulb operates from your local mains voltage, a trip to a local lighting store should get you a replacement lickity split.
I believe it's a 19 Volt and a 19 Watt.....not positive, and know very little about anything actually!
