Is "Greencap" their nickname ?
for those "greencaps" their common nickname for obvious reasons,
This is what i am talking about, while this site states they are popular at high freq circuits, you say not for RF.
I wouldn't use them (and you will never see them in signal paths of HF (high freq and up) circuits) in RF circuits over a MHz or two, they are not stable enough
For example i know that for smoothing we use electrolytics.
yes and also commonly used in audio circuits as interstage coupling of the signal ... between inputs and preamps, then between preamp and power amp stages
Also how can we read it's value ? Is it the same way we read ceramics ?
That was sorta answered in that link.....
capacitors are marked in 5 common ways
1) the direct uF value 100uF, 1uF, 0.1 uF etc
2) indirect uF way, by showing a decimal value, .1, .001 etc ( the leading zero is commonly dropped to save space
if you see a cap with .1 on it, IT WILL be 0.1 uF
3) the 3 digit code, saves lots of space, 106, 104, 103, 102, 683 etc = 10uF, 0.1uF, 0.01uF, 0.001uF, 0.068uF = (68nF / 68000pF)
4) any ceramic, mylar, polyprop, polyester cap marked in whole numbers eg 10, 1000, 2200 is a pF value eg 2200 = 2200pF
5) not really seen any more but really old tubular caps and some very small caps during 70's and '80's used colour banding like resistors
an example was in another thread over the last couple of days .....
you can see the lower one has spewed its guts and let out the "magic smoke"
Dave
