Denon AVR 1804 amp won't switch on
eKretz
Apr 8, 2013
251
I was going to say earlier to check voltages under power like Dave is suggesting but I thought you probably had the receiver too far apart to power it. Checking for whether or not that relay is getting its 12V to the coil would let you know pretty quick if it's operable or toast. Obviously if it is getting the 12V the relay is no good. If it's not, work back from there and find out why.
bushtech
Sep 13, 2016
1,025
Yeah, this is a logistic nightmare. I currently have it still mostly connected with the one side of the main board lifted up so I can get to the foil side. If I do remove the whole thing it's going to be a big floppy setup where the chance of damaging the legs to the 10 big resistors is huge. But not sure I want to go and scratch over there if the problem is probably over here in the corner at the relay.
@davenn: can you measure AC out of that sub trans transformer ? Would this be measured on the top and bottom legs on the RH side of the sub transformer as seen on the diagram?
davenn
14,481
Does a diode come into play? I am connecting the 12V straight to the coil legs of the relay, and I checked data sheet of relay, the coil is not polarity sensitive.
yes it does, reverse the voltage and you are basically putting a short circuit across the plugpack PSU
davenn
14,481
no, the left side is the secondary ( output) the side going to the diodes that I asked for a voltage test on
the right side has mains voltage on it, prefer you not to be playing with mains at this stage
bushtech
Sep 13, 2016
1,025
Thanks dave. Now I'm horribly confused and worried. When I look at the tracks on the diagram the 2 left tracks on the sub trans lead to CP101 AC CORD which is the plug where the mains power plugs into the board.
davenn
14,481
HUh ??
are you not looking at the service manual diagram ??
bushtech
Sep 13, 2016
1,025
Relief. Thank Goodness. No, I am working on page 20 of the manual which I can understand much better
davenn
14,481
ohhhhhhhhhhhh so we weren't on the same page ;)
OK you were on the board layout .... and its opposite to the way the circuit diagram is laid out .... all my comments are referenced to the circuit diagram
bushtech
Sep 13, 2016
1,025
Yeah, so relieved we sorted that out. Was considering giving up electronics there for a moment. But can we work on page 20. It's a more realistic layout of whats going on and I can understand it.
OK Getting 11VAC on secondary legs of sub trans
davenn
14,481
tho it is good to be able to swap between both, the board layout is good for finding where components are, the schematic shows how things are connected ... easier to follow through
OK sounds reasonable
now do the DC on C158
bushtech
Sep 13, 2016
1,025
Just to be sure. Where do I connect the neg lead of the DMM to read DC on C158 ? To neutral leg of mains power?
bushtech
Sep 13, 2016
1,025
the plot thickens. DC across C158= 0.17V
Still want to measure IC 105. Is that also across it's 2 legs?
davenn
14,481
no it's inferring that D149 and/or D153 are faulty
power unit down and you will need to check those 2 diodes
ohhh that may include D152 as well
Do you have any 1N4007 diodes ? ... a very common/popular diode
just replace them if you have spares ... you can always test them once they are out of cct, just for curiosity
bushtech
Sep 13, 2016
1,025
Yes, I've got 1N4007's Surprising as I've still only built up a meagre supply of spares
bushtech
Sep 13, 2016
1,025
I will probably have to pull all those diodes to properly check them and then I might as well replace them as they're out.
Interesting, using X1 reading on AMM diodes check good. deflection one way. Using x10K scale diodes all fail. deflection both ways. Back planes could come into play here?
