Daniel Barlow
- Oct 27, 2016
- 1
- Joined
- Oct 27, 2016
- Messages
- 1
Hello I'm trying to recreate the circuit board and I'm having difficulty identifying the two 8 Pin IC's (they're
the same) they have the number 7530 and looking it up i see some component come up that doesn't match what this circuit does-- as well as the round 3 pin object next to the 555 any help you can offer would be greatly appreciated thank you .
This circuit has a 4017 and a 555 and it simply makes some leds flash. what might be the function of the two 8 Pin IC's, and what is that weird component with the metallic center over to the left by the 555 timer?
Thank you,
Daniel
the same) they have the number 7530 and looking it up i see some component come up that doesn't match what this circuit does-- as well as the round 3 pin object next to the 555 any help you can offer would be greatly appreciated thank you .This circuit has a 4017 and a 555 and it simply makes some leds flash. what might be the function of the two 8 Pin IC's, and what is that weird component with the metallic center over to the left by the 555 timer?
Thank you,
Daniel
